AMS F1 intake manifold question
Old Jan 23, 2014 | 06:34 AM
NigHtcRawl3R's Avatar
Hey guys and gals,
Can someone please tell me the size of the vacuum ports on the AMS intake mani or what size NPT fittings that would go in each port? There are 4 of them that are the same and then there is a bigger one by the map sensor. The manifold is on the car at the moment but don't want to take it off...yet.
Looking on installing a catch can and found a NPT to -AN adapter.
Any help would be much appreciated.
Thanks in advance
Old Jan 23, 2014 | 08:08 AM
Ev0ikon's Avatar
Do you really want a catch can connected to the manifold?
Old Jan 23, 2014 | 08:15 AM
Pssst's Avatar
Was wondering the same thing myself... Your best bet would be to contact AMS but I'm sure someone on here knows the details.
Old Jan 23, 2014 | 08:24 AM
RallySport Direct's Avatar
Silver Sponsor
4 x 1/8" NPT
1 x 1/4" NPT
Hope that helps you out
-Dallin
Old Jan 23, 2014 | 08:50 AM
Ev0ikon's Avatar
Hope the OP doesn't F@#$Up this awesome manifold.
Old Jan 23, 2014 | 10:58 AM
I hope I don't? Lol. I found a NPT to -AN adapter that mates up to a -10AN check valve. Thought that would work well. Not sure how I could stuff it up though?
Thank you Dallin for the sizes
Old Jan 23, 2014 | 01:07 PM
Jsiebert's Avatar
The check valve goes in valve cover line not intake manifold. You sure you should be installing parts when you don't know where they go/ how they are set up? Not trying to be rude but maybe a shop should finish install
Old Jan 23, 2014 | 05:01 PM
No thats fine. Catch can is going to be installed in between pcv and manifold. A check valve is needed in the line going from the manifold to catch can to stop the can from pressurizing when on boost. But I'm guessing you already knew that.
Old Jan 23, 2014 | 06:13 PM
hatesposers's Avatar
Um.....
The catch can will still be under pressure under boost if you hook it up to the intake manifold even with a check valve...
under boost, more gas leaks past the rings, causing more gas in the crankcase, causing more gas in the valve cover, causing more gas in the catch can....
If it was routed to the intake, it would hit a wall then, as your check valve will not open until your PCV system was higher than your boost pressure. = not good.
Route it to the intake BEFORE the turbo like you should.
Old Jan 23, 2014 | 06:53 PM
Originally Posted by hatesposers
Um.....
OK...
I have 2 catch cans I want to install. One between the PCV and mani and the other between vc vent and intake pipe. Upon installing the PCV side, stock PCV will be removed hence why I am putting check valve in between mani and can. Is this wrong? It's been done many times. This is basically how the stock PCV system works. Uses manifold vacuum to help recycle blow by gas back into the cylinder. But in this instance, a can will be in line to help catch the contaminants. Correct me if I'm wrong?
Perhaps a vented can would be of more use?
Old Jan 23, 2014 | 07:00 PM
The stock system doesn't use manifold vacuum, it uses pre turbo intake vacuum.
Pre-turbo is always at or below atmosphere pressure, The intake manifold is not.
Old Jan 23, 2014 | 07:20 PM
OK got ya. Modifying can to suit. Thanks for the input guys.
mrfred
Oct 8, 2023 04:45 AM
EGbeater
34
Mar 1, 2015 09:52 PM
Phantom09
Automotosports - Illinois
Apr 16, 2010 01:55 PM
drewblueeye
Jan 31, 2007 05:14 PM
Thegame
Jul 10, 2005 02:07 PM
