Evo iv map sensor
Old Jan 23, 2014 | 08:49 PM
dubs&boost's Avatar
Evo iv map sensor
How many bar does the map sensor on an evo iv support? and is an omni or similar sensor compatible with the evo iv? i have an Evo vi ecu.
yes i have looked on lancer register, useless over there since it won't let me post unless i pay the members fee
Old Jan 24, 2014 | 11:45 AM
jrainwater's Avatar
Is it possible to swap in an ecu from an EVO 8? I feel like I read a tread on here about a guy doing that and it working. If so it would open you up to a ton of stuff that probably isn't available on an ecu from a vi. Just throwing it out there. Think of all the 2 byte mods and there's already ways to run the omni 4 bar on here with an EVO 8 ecu.
Old Jan 24, 2014 | 01:00 PM
dubs&boost's Avatar
i know i can run an evo 8 ecu but then i lose this base map on this ecu that was professionally tuned. and more money blah blah
Old Jan 24, 2014 | 01:37 PM
Yogi_B's Avatar
I post over on the MLR and i'm not a paid member.
Anyway, evo4s don't run MAP sensors, only MAF, I don't even think an evo6 ecu would support it, but I could be wrong.
Old Jan 25, 2014 | 07:25 AM
jrainwater's Avatar
Couldn't you just use ecuflash to copy all of your maps over to the VIII ecu? 8 ecu's are going for pretty cheap on eBay these days.
Old Jan 25, 2014 | 08:39 AM
EvoVan's Avatar
^^I don't think its as simple as copy and paste. You can add a MAP sensor and get it to work with the right wiring however.
Old Jan 25, 2014 | 10:15 AM
dubs&boost's Avatar
So then I am much better off running a boost controller? Will evoscan not log any boost because there is no map sensor?
Old Feb 1, 2014 | 10:09 AM
EvoVan's Avatar
A boost controller is the way to go for now it seems, if you cant find someone with the expertise to wire a boost solenoid and make the ECU adjustments. Evoscan will not log boost and so you will have to make note of the peak boost and where the boost holds for each run and use that the guide your tuning.
timmy_red
Jul 20, 2019 02:18 AM
Tyrel Bursaw
Mar 16, 2017 11:04 AM
AWD_fetishhh
HKS
Jan 6, 2016 12:50 AM
silverbur
Dec 3, 2014 02:32 AM
PoisonIV
Nov 25, 2012 07:39 PM
