Flex fuel sensor -- where is yours mounted
Old Jan 27, 2014 | 02:09 PM
TheBoz's Avatar
Not sure how many people have a flex fuel sensor on there car, but I am trying to find a good place to mount mine. I was thinking under the car near the gas tank.
Anyhow if you have pics post them up.
Old Jan 27, 2014 | 03:28 PM
240Z TwinTurbo's Avatar
Old Jan 27, 2014 | 05:41 PM
TheBoz's Avatar
Do you have it on the return or supply side?
Old Jan 27, 2014 | 06:00 PM
heel2toe's Avatar
I believe most put it on the return line so it will not restrict flow.
Old Jan 27, 2014 | 07:30 PM
Mine is on the return, but you can run on the supply. It is a -6 equivalent.
Old Jan 27, 2014 | 08:04 PM
wizzo 8's Avatar
Originally Posted by 240Z TwinTurbo
Same place I mounted mine.
Old Jan 28, 2014 | 02:10 PM
galantman03's Avatar
what does this do? I mean i know it gathers ethanol content, but can you used it with a stock ecu? how would it adjust the values in the ecu?
Old Jan 30, 2014 | 08:27 AM
Biggiesacks's Avatar
It gives you the Gasoline to Ethanol ratio of the fuel. So if you where tuned on a certain blend you can adjust your boost / timing/ afr's if you happen to get a really ****ty tank or something. Most people, I believe, would be using a display to give them a readout of what that ratio is. You could hook it up to the ECU for logging purposes, but for the most part the ecu itself wouldnt be able to do anything with the information.
Edit: i was way wrong about the ecu using the data. Apparently there is a patch to give it flexfuel capabilites. I havent read through it yet but here is a link https://www.evolutionm.net/forums/ec...n-evo-ecu.html
Old Jan 30, 2014 | 08:37 AM
STLEVOIX's Avatar
Old Jan 30, 2014 | 08:56 AM
Originally Posted by STLEVOIX
super clean install!
Old Apr 15, 2015 | 04:37 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
^ Great location
Old Apr 16, 2015 | 05:30 AM
DSMolition's Avatar
I mounted mine the same way on the firewall with -6 an fittings. In addition, these are not recommended to be used on the feed side. They are not meant for fuel pressure.
real fast
20
Oct 11, 2016 09:37 AM
Camaran
Feb 3, 2016 05:37 PM
jacked cobra
Jan 28, 2015 02:33 PM
Marcac
E85 / Ethanol
Aug 22, 2013 09:15 AM
mrfred
E85 / Ethanol
40
May 20, 2012 01:22 PM
