abs sensor
Old Feb 10, 2014 | 09:49 PM
carlosevo's Avatar
abs sensor
So I need to remove the abs sensor from the steering knucle is any tool that I can use so I don't break the sensor
Old Feb 11, 2014 | 10:07 AM
ProPilot04's Avatar
Are you replacing the sensor with a new one? Presumably not... but no, there isn't a special tool or anything. It should just be held in place by a that one bolt, and the pressure from the O-ring, so with some wiggling, it should pop right out... but it will be in there snug.
Iirc, it's just a hall sensor (magnet) so there isn't too much that can be damaged. I might try grabbing the base of it with some pliers, or vice grips set lightly (tight, but not toooo tight).
Why are you pulling it out of curiosity?
Old Feb 11, 2014 | 11:11 AM
jrainwater's Avatar
Is there any reason you started 4 different threads asking the same question? That sensor is a beyotch to get out and I would be amazed if you get it out without breaking it. Good luck and stop making tons of threads for the same question please.
Old Feb 11, 2014 | 11:24 AM
carlosevo's Avatar
Whats your problem bro you own this forum or what??
Old Feb 11, 2014 | 03:38 PM
jrainwater's Avatar
No you're not supposed to post the same question 4 times just to build up your post count. Fail.
Old Feb 11, 2014 | 03:58 PM
ProPilot04's Avatar
Settle down kids.
FWIW, I only saw 1 post. Obviously you aren't supposed to do that.
The question now becomes... since you chose to ignore my trying to help you, and just decided to yap about doing whatever you want, do you actually need help? Or are you just some trolling JA?
Old Feb 11, 2014 | 04:12 PM
jason42003's Avatar
I'm glad I'm not the only one that noticed I'm with jrainwater I think it's more about the post count to get into the for sale forums.
Old Feb 11, 2014 | 05:01 PM
jrainwater's Avatar
Yeah that sensor is plastic and it breaks super easy because of all the heat cycles the brakes go through. It ends up being super brittle and I tried every trick in the book to get one out once and it still broke. And propilot there are 3 threads in general and one in how to, same op, same question. Just saying...
Old Feb 11, 2014 | 10:54 PM
carlosevo's Avatar
Thanx for you help!!! an I didn't answer soon because I was too busy trying to take out the stupid sensor
Old Feb 12, 2014 | 01:55 PM
ProPilot04's Avatar
Damn kids.
Did you manage to get it out of there?
Rico8638
Jul 13, 2019 10:29 PM
irwintan27
For Sale - Part Outs
Sep 14, 2016 02:01 AM
BuiltS13
18
May 23, 2016 08:04 AM
shawnevo8
Dec 23, 2015 12:39 AM
Luke18
Sep 13, 2012 06:03 AM
