BOV not opening fast enough at full boost
Old Feb 28, 2014 | 01:11 PM
knx2's Avatar
Red face BOV not opening fast enough at full boost
Hey. So I have been racking my brain trying to find out why my Synapse BOV would function perfect under 19 pounds of boost but fail to open fast enough at over 20. Today I finally was able to put my BOV on a friends car with no change in the configuration and it would be flawless on his car.
Here is a log.
https://docs.google.com/spreadsheet/...=0&output=html
Does this look normal as far as vacuum?
Thanks.
Old Feb 28, 2014 | 02:14 PM
asu11's Avatar
Have you checked for boost leaks? It is staying shut under boost? Is the vac line going to it sufficient in size and the same size all the way to the source?
Not very familiar with these but isnt there a few different configurations you can set these up with? May want to double check that also.
Old Feb 28, 2014 | 02:15 PM
asu11's Avatar
Dont pay attention to evoscan for vacuum readings. I know mine doesnt go past a certain number either. Look at your gauge.
Old Feb 28, 2014 | 02:17 PM
knx2's Avatar
I have tried every configuration and it never blows off at full boost. On my friends EVO it blows off just fine at full boost and we run about the same boost levels 29PSI.
My vacuum line is right from the intake manifold to the BOV port. Nothing else is attached to it.
Old Feb 28, 2014 | 02:18 PM
knx2's Avatar
ah ok. My AEM gauge reads 26 at idle so it should have plenty of pulling power. I can see the BOV working by watching it and revving the engine manually.
Old Feb 28, 2014 | 03:41 PM
asu11's Avatar
Do you guys have the same turbo/motor? If not then his 29psi is more/less than your 29psi.
Old Feb 28, 2014 | 10:57 PM
knx2's Avatar
well yea... but still shouldn't the BOV open after going full throttle and letting off the throttle?
I removed the preload spring and tried just A with B VTA, just B with A VTA and A + B. A with B VTA was the worst.. fluttered at low boost.
Old Feb 28, 2014 | 11:16 PM
asu11's Avatar
No idea on the combinations. Flutter at low boost is normal. You dont want it at full boost.
Old Mar 2, 2014 | 09:56 AM
knx2's Avatar
Yea.. I cannot figure out why it doesn't open at full boost. UGH.....
Anyone have any ideas on what I can try?
Old Mar 2, 2014 | 10:43 AM
EvoJoeIX's Avatar
The spring is too stiff in the bov valve. You have to find the happy medium with on that holds the valve closed at idle and will open fully under boost release. You cant always go off the charts from the company either
It took me i think 3 springs in my tial to find the one that worked. And it wasnt the one the they had listed on the chart for my vaccum level
Just my .02
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
Clipse3GT
15
Jun 12, 2014 03:13 AM
voidhawk
Mar 3, 2013 02:01 PM
EvoPooPoo
25
Jun 26, 2011 12:30 AM
Clipse3GT
18
Dec 16, 2009 02:48 PM
