Again Idle help
Old Mar 7, 2014 | 06:19 PM
steven121's Avatar
Again Idle help
Well logged my car and its around 28 steps
Im curious to see if I raises the lower steps a little higher will that prevent my idle dip issue.
I trying to see which sensor is starting to die out either the tps or front o2 - i do have a small boost leak in the licp that i will ve replacing
Symptoms
Sudden afr change while driving rich to lean then back normal
While at idle sometimes it will run lean and once i give it throttle it doesn't run as rough
And constant idle dip
vmrevo9
Mar 15, 2015 02:21 PM
J5isalive2
Sep 1, 2014 01:05 PM
johntrav
Feb 5, 2014 03:27 PM
jadyer
Jan 18, 2014 06:20 AM
AdrenalineRush
Apr 25, 2013 01:57 PM
