lifter tick suggestions on new lifters?
Old Mar 10, 2014 | 06:16 PM
ok cool!'s Avatar
and also should I replace valve springs and retainers while they are in there? im running 270 cams I bought the car not knowing whats underneath the cams just wondering if anyone knows a good lifter and valvespring duo that works well with cams.. thanks!
Old Mar 10, 2014 | 06:27 PM
sujinX's Avatar
There's zero tick lifters. I think gsc website has them.
Old Mar 10, 2014 | 08:24 PM
Leonthefaded's Avatar
GSC Zero Tick Lifters
Old Mar 10, 2014 | 08:49 PM
barneyb's Avatar
The lifters get all kinds of junk in them. What scares me is the little chunks of metal. I guess better in the lifter than somewhere else.
The thing is don't ever run oil for an extended drain interval. This may cause the oil filter to bypass. I had a sludged up DSM (running crummy Mobil conventional oil did that) and my oil filter would bypass at 1800 miles. I could tell because the oil would suddenly turn dark. Soon after that I had to change lifters.
Also, some oil filters have the bypass valve on the top and some on the bottom. Run a filter that has the bypass on the top. A bypass valve on the bottom flushes all the crap in the filter into the engine if it opens. If you aren't sure about the filters you are using cut one open.
Old Mar 10, 2014 | 09:45 PM
ReidFletcher's Avatar
I swapped to the Topline revised lifters. $100. Cheap and very quiet lifter.
Old Mar 10, 2014 | 11:09 PM
Do you happen to know which oil filters those might pertain too?
Old Mar 11, 2014 | 09:57 AM
Biggiesacks's Avatar
There is a procedure for cleaning the factory lash adjusters. It involves diesel fuel. I would suggest looking into this before buying new ones.
Old Mar 11, 2014 | 01:21 PM
barneyb's Avatar
There's more than several videos on youtube where people have cut oil filters open to show you the contents of the can. Filter elements that are solid metal on the bottom have the bypass valve at the top - usually. I say usually because I've seen at least one filter that appeared to have no bypass valve.
So, go to youtube and type in "oil filter reviews". There's one caution here - designs change and various factories may make the same brand. So two identical looking filters may be different on the inside. If you really want to know what you are getting, buy two and cut one open.
Howulikemyevo
40
Sep 29, 2021 04:39 PM
4G63_EVO
May 7, 2017 06:34 PM
benIX
Mar 23, 2017 09:29 AM
b16a95eg
Apr 30, 2016 05:16 PM
navr11
Mar 6, 2016 07:06 PM
