Fuel Pump Hanger Filter??
Old Mar 13, 2014 | 11:44 AM
jrainwater's Avatar
Does anyone know a way to bypass that filter inside the pump hanger? I know it can't be serviced but if I could bypass it and put another filter inline to replace it that would be nice. I'm pretty sure its clogged and I know its old so.....thanks
Old Mar 13, 2014 | 12:43 PM
egis's Avatar
why bypass if you can buy new one for $15 and replace it.pls explain your concept.
Old Mar 13, 2014 | 12:45 PM
egis's Avatar
oh I'm sorry i thought you talking about sock filter.
Old Mar 13, 2014 | 07:38 PM
jrainwater's Avatar
No I swapped out a loud walbro 255 for a aeromotive 340 and the car barely stayed running. I had to keep feathering the gas just to keep it running and fuel pressure never got above 10psi. so I put the walbro back in and its doing the same thing now. Before the swap it was working perfect I just wanted a little more fuel for the ported intake manifold and throttle body I'm about to install. I already checked the plugs and no fouling at all. It's starving for fuel and the ONLY thing I did was swap the pump. Any ideas???
Old Mar 14, 2014 | 02:53 AM
AreSTG's Avatar
voltage or something to the pump assembly?
Old Mar 14, 2014 | 06:50 AM
jrainwater's Avatar
I've got a 12 volt pump rewire kit installed. I found an old thread where another guy had the same issue and it ended up being the rubber insert on the bottom of the fuel pump is blocking the priming hole. You just have to cut a little bit of the rubber away and let it breathe. I figured out my problem, mods please close this thread.
Old May 30, 2015 | 03:31 AM
Rom's Avatar
Rom
I am having this exact problem!! Been tearing my hair out (see my other thread).. Hopefully you are still around - how did you solve this?? Looks like you mentioned the filter inside the hanger (which I didn't know about?), but then mention some rubber blocking the priming hole... Can you confirm what solved it for you please?
Thanks!
S.
Old May 30, 2015 | 06:48 AM
IzzyRS's Avatar
Thanks!
S.
Hey Rom, the second picture in this thread shows the filter element inside the plastic housing for the fuel pump.
https://www.evolutionm.net/forums/ev...-evo8-9-a.html
jrainwater
27
Jul 15, 2017 03:21 AM
Nullify
Dec 26, 2015 08:54 PM
Englando
15
Sep 8, 2013 08:08 PM
xCASHx
Toronto Lancer Club
11
Jul 26, 2009 03:44 PM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Apr 12, 2006 12:54 PM
