4g64 timing marks question.
Old Mar 16, 2014 | 08:13 AM
babaz7's Avatar
i had a failure on my manley crank, so a friend told me to use my oem 2.0L crank on my 4g64 block...
now i want to know is will i have to set the timing marks the same as i did before with the manley crank? they both are the same size right?
Old Mar 16, 2014 | 09:52 AM
michaelrc51's Avatar
Was displacement were you running? Was size was your Manley crank?
Old Mar 16, 2014 | 11:19 AM
EvoJoeIX's Avatar
No. You cant use the same timing marks.
The proper way would be to degree the motor when its out of the car
Old Mar 16, 2014 | 11:55 AM
babaz7's Avatar
i had a 2.1L displacement...
im not sure about the manley crank size but from what i heard the 2.0L and 2.1L use the same size crank...
Old Mar 16, 2014 | 11:58 AM
babaz7's Avatar
how cant i use the same timing marks as before when the 2.1l and 2.0l have the same crank size...??
im still utilizing my 4g64 block, with the same pistons and rods, just the crank will be oem one which is i guess the same size as the manley one..
Old Mar 16, 2014 | 05:10 PM
EvoJoeIX's Avatar
Didnt realize you had a 64 block before
Old Mar 16, 2014 | 07:04 PM
babaz7's Avatar
so im good right?
i can use same timing marks as before?
Old Mar 17, 2014 | 06:14 AM
EvoJoeIX's Avatar
Im not familiar with them so i couldnt tell you
Try to pm arron at english racing, he has always helped me out when i had questions and hes very familiar with the 64 blocks and crank combos
Old Mar 17, 2014 | 06:48 AM
batty200's Avatar
Yes use the same marks as before. The cranks are the same functionaly.
Old Mar 17, 2014 | 08:40 AM
hashaam81's Avatar
Timing marks should remain the same. Was the Manley forged or billet?
sktng22
23
Dec 25, 2011 11:20 AM
hybrids14
Mar 19, 2007 01:06 PM
nianlala
30
Feb 5, 2007 10:14 AM
Rau
14
Sep 23, 2005 07:56 AM
Aby@MIL.SPEC
17
Feb 2, 2005 05:04 AM
