Car Sometimes Gets Hot While Stopped
Old Mar 17, 2014 | 11:18 AM
iD33's Avatar
With the car off gently squeeze the rubber coolant hoses. Rudimentary way of sourcing the leak. Chances are you have hairline break which looks sealed but cracks open when under pressure. My water feed line had the same exact problem. Good luck.
Old Mar 17, 2014 | 11:40 AM
kaj's Avatar
kaj
also, any coolant around where the hoses connect? they like to have issues there, too.
Old Mar 17, 2014 | 11:50 AM
jjk23's Avatar
Check all the connections in your cooling loop. Picture #1 shows some coolant sitting on a coupler. Hopefully it is something as simple as a loose clamp.
Good luck!
Old Mar 17, 2014 | 01:33 PM
KJS's Avatar
KJS
Looks like its coming from here this hose. I think the oil feed like dug a hole in the side of the rubber tube. Anyone know what is called so I can get a replacement?:
or this metal housing on the side of the block, thermostat housing?:
Old Mar 17, 2014 | 02:02 PM
kaj's Avatar
kaj
i wish i could see pics.. so it's your lower radiator hose? it goes from the driver side of the engine to the bottom of the radiator?
Old Mar 17, 2014 | 02:45 PM
iD33's Avatar
No clue on the hose name. I went to an Autozone and asked for a equivalent hose of the same inner diameter that is safe for coolant.
Old Mar 17, 2014 | 02:49 PM
kaj's Avatar
kaj
is it the water feed or return for the turbo?
Old Mar 17, 2014 | 04:55 PM
KJS's Avatar
KJS
Ended up being that coupling on the coolant feed line to the turbo. Thanks for all the help gentlemen. Much appreciated.
HKSevolutionNYC
Feb 2, 2016 10:27 AM
Eleventy5
Lancer Troubleshooting
Oct 1, 2015 12:24 PM
SilentCool
Sep 22, 2015 05:57 AM
evotris
Jul 6, 2014 10:01 PM
majeddy
Jun 13, 2008 07:16 AM
