I need a straight up answer about cams EVO 9
Old Mar 26, 2014 | 01:56 PM
Igaly1021's Avatar
i know that on Evo 8 cams and evo 9 turbo will help alot, but I read alot of different opinions for evo 9 cams with stock turbo some say yes some say no. I have read the sticky "big cams small turbo" and "Everything I've learned after 4+ years with my Evo" threads but I can't a straight up answer.
current mods:
HPI FMIC
Turbo Master BOV
Drop-in Filter
Future mods:
DP & TP
1000cc Injector
255 Fuel pump
Fuel pump Re-wire kit
Cams?
with that mod list are cams worth it? or are stock cams good enough?
Old Mar 26, 2014 | 02:10 PM
jason42003's Avatar
The right cams will give you more power, there's no use putting 280 cams on a stock turbo, but 260's and 270's will get you some more power. The larger cams are really only beneficial with the larger turbos.
Old Mar 26, 2014 | 02:14 PM
mdsevo06's Avatar
I would upgrade your exhaust, fuel pump, injectors, LICP and a GM 3-port on e85, with stock cams. The money you spend on cams and installation, you could upgrade to a HTA71 instead and already have the supporting mods.
Old Mar 26, 2014 | 03:07 PM
Igaly1021's Avatar
thank you thats the answer I was looking for
I'm honestly looking to get 400whp I got the tuner and thats all he does dsm & evo but I just wanna have everything ready before i take it to him you know so if stock cams are able to handle 400whp then ill stick with stock but if i need the extra ponies then i wont mind getting cams
Old Mar 26, 2014 | 03:11 PM
roach85's Avatar
GSC S1's seem like a wise choice for stock turbo
Old Mar 26, 2014 | 03:49 PM
Igaly1021's Avatar
ok good enough thanks for your help guys
Old Mar 26, 2014 | 07:41 PM
lostsoulsevo's Avatar
You need cams to make 400whp on stock 9 turbo, even with E85
Old Mar 27, 2014 | 04:45 AM
Atrophical's Avatar
I've seen stock cams, tuned on E85 with bolt on's produce over 400.
It's been done, personally I think that's a lot of strain on a stock up but that's just my .02
Old Mar 27, 2014 | 06:33 AM
newbieEVO8's Avatar
Big cams on a small stock turbo will produce gains. I ran GSC S2 cams on the small 03 evo 8 stock turbo and saw large gains.
Don't believe the hype of stock turbos can't handle big cams.
Old Mar 27, 2014 | 08:06 AM
boostedmkiii's Avatar
I would agree. I have had great results with FP4r cams with my stock 9 turbo. I also know of a DSM with 288s spinning the crap out of a 16g...
Old Mar 27, 2014 | 01:37 PM
jason42003's Avatar
It's not that the larger cams won't produce power on stock turbos, they do. The problem with big cams is they shift your power band to the right. The stock turbo is already experiencing boost creep by 6-7k, it gets worse the higher up in the rpm band you go. The reason they work with larger turbos is because the larger turbos will continue to make power further up in the rpm band. So long story short the larger cams will produce more power with a stock turbo, but you are not using them to their full potential because the turbo isn't able to continue to make power at those higher rpms.
Old Mar 30, 2014 | 05:37 PM
Igaly1021's Avatar
ok cool thanks for the tips guys...btw did you guys do both cams or just the mivec cam cuz i seen a few threads about just doing the mivec cam
Old Mar 30, 2014 | 10:04 PM
dw cuz's Avatar
s2 cams work well
Old Mar 31, 2014 | 05:36 AM
asu11's Avatar
Well without cams you would make 0 hp
But seriously I made over 400whp on stock ix cams as do many ppl
Old Mar 31, 2014 | 11:46 AM
sujinX's Avatar
do the s2 cams. stock turbo with i/h/e i made power everywhere.
there was no lag, no drive-ability issues, no stalling issues, no ac issues nothing.
altho it took some tinkering to get it all to sort out but its great now. (tb seal problem)
BUT, since i have an 8, it lopes pretty hard and its annoying. so im looking to remove them. i know on the 9's with mivec u can tune out the cam loping.
payway87
43
Sep 9, 2014 03:50 PM
winkdogydog101
12
Oct 9, 2012 04:01 PM
Don Q
Nov 6, 2010 02:20 PM
GST Motorsports
Evo X Dyno Results
30
May 11, 2010 09:29 AM
s2krn
15
Feb 4, 2008 08:18 AM
