TW for a retrofit group buy
Old Apr 6, 2014 | 07:35 AM
rahmacol's Avatar
Here is a link to the complete retrofit kits they offer.
http://www.theretrofitsource.com/com...ofit-kits.html
Old Apr 6, 2014 | 06:24 PM
deylag's Avatar
There are a lot more options available now. Its hard for beginners to tell which projectors are going to fit.
Old Apr 7, 2014 | 08:45 AM
llDemonll's Avatar
Ideally you want a TSX projector. The FX-R's fit, but require a LOT of custom work on the evo housings. You have to cut into the blinker area and all that jazz
If anyone retrofits evo projectors, do yourself a favor and only use TSX projectors. You trim one corner of them and they can basically mount right up to the stock mounting points in the Evo
Old Apr 7, 2014 | 06:34 PM
hatesposers's Avatar
Originally Posted by llDemonll
you're going to be VERY hard pressed to
1. find people who want to do with without posting prices
2. want to do this at all. the evo lights aren't terrible and for most people, the change isn't worth the time or money investment
He should also have a hard time keeping this post open because group buys are prohibited by non-vendors.
I'm surprised a moderator contributed to this thread without closing it.
Old Apr 8, 2014 | 07:08 AM
rahmacol's Avatar
I was gauging interest. Not starting a groupbuy. It's obviously not going well so thanks for adding to the pile. Lol
Old Apr 8, 2014 | 07:11 AM
rahmacol's Avatar
I went to the forum they have and they've introduced the 3.0 d2s with comparison shots. You should look at it. I honestly don't want to do much cutting since I've never worked on this type of headlight and wouldn't want to risk damage and not be able to fix it.
Old Apr 8, 2014 | 09:07 AM
llDemonll's Avatar
You mean the Mini D2S? I wouldn't use that over a TSX projector if given the choice. the Mini D2S is a square lens, it will look like crap in a circular housing
Old Apr 8, 2014 | 10:39 AM
flippymcbean's Avatar
I thought that they made a circular lens. No?
Old Apr 8, 2014 | 12:34 PM
llDemonll's Avatar
I lied, they do still have the circular lense available with these
My opinion still stands that the TSX projector is the best to retrofit into an evo
Old Apr 8, 2014 | 01:32 PM
I want try the 3.0 D2S just because. Hahaha.
Old Apr 8, 2014 | 01:59 PM
Kreeker's Avatar
Does the TSX projector require a lot of modification?
Old Apr 8, 2014 | 02:22 PM
llDemonll's Avatar
no, you basically just trim off one corner of the mounting bracket, drill new holes in the mounting bracket, and mount it on the stock bracket points on the evo headlights
Old Apr 8, 2014 | 08:20 PM
rahmacol's Avatar
I guess your right but performance.....TSX projectors are hard to come by. Where do you get yours?
saw your post afterwards.
I thought I saw they offer 2 options.
Old Apr 8, 2014 | 08:24 PM
rahmacol's Avatar
heres a link for some info on the new D2S.
http://www.hidplanet.com/forums/show...o-Mini-D2S-3-0
Old Apr 9, 2014 | 06:24 AM
Kreeker's Avatar
I noticed the TSX projectors are listed as low-beam rather than bi-xenon. I'm assuming bi-xenon means low beam and high beam? If you have a bi-xenon projector do you need 2 separate hid ballasts, 1 for the low and 1 for the high? On an actual TSX do they have another projector for the high beam?
I feel like it would be nice to have both the low and high beams HID.
