Help!
Old Apr 5, 2014 | 10:38 AM
spooldoodle's Avatar
Help!
I just replaced timing belt and counter balance shaft. And I was wondering if I didn't line up the oil pump sprocket would that cause a vibration sound. Every thing is lined up pin perfect, but when the car get anywhere over 3k rpm it starts to vibrate. Driving or in neutral
Old Apr 5, 2014 | 11:08 AM
Ev0ikon's Avatar
Did you really replaced the counter-balance shaft?
And yes if the c-b shaft not lined up correctly against the crank angle it will cause vibrations.
Old Apr 5, 2014 | 11:41 AM
Thanks everything is lined up perfectly, I just took everything apart to make sure again and everything is mint, just don't know why it was vibarating? I'm gonna start it up in a few minutes to see if it still makes the sound
lznk41
17
May 2, 2020 07:18 AM
slicksta69
15
Jun 20, 2016 09:23 AM
bluevilevo8
11
Sep 7, 2015 06:30 AM
MRadjahoe
Dec 5, 2013 09:47 AM
fanbelted
Jul 3, 2009 08:23 AM
