Map EF2.5 or EF3
Old Apr 9, 2014 | 03:56 PM
RcEvo09MR's Avatar
Map EF2.5 or EF3
Which turbo will be better for 400-450 with stock head and cams..I got Bolt ons..Exhaust,downpipe,HFC,fic 1100cc injectors,intake, Ebc, walbro 255 pump..I want some efficient..less boost but make good power..not worried about lag..thanks for the input
Old Apr 9, 2014 | 04:12 PM
jason42003's Avatar
I asked Map this question directly about a week or so ago, and if you are planning to run stock boost levels they suggest the ef3 for that power range. You can probably do it with the 2.5 but I prefer to make my power comfortably than pushing parts to their limits. Only difference in the setup is that I am planning to run gsc s2 cams.
Old Apr 9, 2014 | 04:39 PM
tschad's Avatar
id stick to fp green, red, or a black. all will make that kind of power. at the end of the day id trust a company that specializes in turbos and has a reputation for designing great turbos. but it also comes down to money, map definitely tends to be a lot cheaper.
Old Apr 9, 2014 | 05:23 PM
Bhsj13's Avatar
I would vote: EF3 but that power level will not be achieved with stock cams. S2's have worked well for evo 9's.
Old Apr 9, 2014 | 06:19 PM
slowsrt4:('s Avatar
To answer your question EF3, you won't make the power you want without cams on the smaller turbo. But if it were me I would get a FP Green or Red for what you're trying to make.
Old Apr 9, 2014 | 08:14 PM
RcEvo09MR's Avatar
Thanks for the Input!! yea my boost levels are higher than stock 27psi 91oct and 30 e85.one of the reason i want a better turbo..run less boost more power..Yea ill do cams with springs down the road..i dont want to Open anything up at the moment!..Id get an Fp red but money is the downfall....
Old Apr 9, 2014 | 08:36 PM
TommiM's Avatar
I would get the FP Red. Its a great turbo, one downside is that FP has updated the turbine housing design so now they cost that much more.
Old Apr 9, 2014 | 09:01 PM
RcEvo09MR's Avatar
yea thats why im not shopping for an FP turbo.. Dont have Enough funds for one at the moment
Ude Lose
45
Mar 14, 2016 06:16 PM
Tekniq
Dec 10, 2015 03:46 PM
KJS
Nov 6, 2015 08:36 AM
ghost911
Aug 27, 2015 09:20 PM
TitanMotorsport
Apr 26, 2013 03:52 PM
