Oil consumption on track?
Relieving the crank case pressure could stop oil from blowing passed your tubo seals and into the intake if that is the cause.
Using large lines such as a 1/2, 5/8, or 9/16 (-10an) will help relieve crank case pressure using the intake as a vacuum. A vented system will not function as well as there is no vacuum source. The can should catch any fluids, however there should not be much from this can vs a can that goes between the VC and IM.
Thanks!
You are limited by how much air you can move and by your vacuum source. Bigger line = more volume = less crank case pressure.
Thanks!
crcain
Apr 29, 2009 12:38 PM
