No start after winter storage
Old Apr 23, 2014 | 04:46 PM
N1ck Z's Avatar
Did you figure it out yet?
Old Apr 23, 2014 | 10:14 PM
TimIacobucci's Avatar
Test the resistance of the injectors with a multimeter. Injector open code is just that. If the injectors test fine then it's a connection between the injectors and ecu. If you have the resistor bypassed this is a likely source of a wiring fault vs the rest of the stock harness that's all working fine. Just recheck connections and follow standard electrical circuit troubleshooting diagnostic procedure.
Old Apr 24, 2014 | 07:12 PM
xPSYCHOxWHITEx's Avatar
haven't got it yet...im calling busher racing tomorrow, i have there COP setup to see if they have heard of similar problems or send the box for them to test... I stored it empty and filled it back up so its not fuel and the resistance is fine on the injectors so if its not the ignition system I will look into the wiring if not then im gonna get it up to MAP one of these days
Old Jun 19, 2014 | 08:49 PM
Turns out it was the wires out of the resistor pack even tho bypassed need to be connected to complete the circuit.....thanks to the guys at RS in Minneapolis....I thought that since it was bypassed it wasn't being used
khoyer
Dec 6, 2016 10:00 AM
TurboKushGS-T
Lancer Troubleshooting
Apr 9, 2015 08:31 PM
ZanarkO
11
May 5, 2014 08:11 PM
5LEEPERISAH23I
Sep 6, 2011 05:28 PM
weebles
12
Mar 16, 2010 04:28 PM
