Valve cover modification question
Old May 15, 2014 | 07:56 PM
Cmax's Avatar
So, I am going to be drilling and tapping my valve cover for two -10 AN fittings on the side. I was wondering what you guys have used to seal the fitting in the valve cover? I've seen one person use teflon tape, but I was wondering if anyone had any success with some other sealants.
Thanks!
Old May 15, 2014 | 08:09 PM
Boostin_hard's Avatar
i just used AN 0 ring fittings
Old May 16, 2014 | 08:39 AM
lostsoulsevo's Avatar
High temp epoxy, no issues here
Old May 16, 2014 | 09:49 AM
19DB794's Avatar
They do make a high temp thread sealant. I forget the name but I used some on my brake bleeder screws when i reassembled my calipers.
Old May 16, 2014 | 02:31 PM
Cmax's Avatar
Cool, thanks for the input guys. Going to start drilling this weekend.
Old May 16, 2014 | 03:14 PM
desiromeo812's Avatar
make sure you either remove the baffles or figure out a way to keep the shavings out.
Old May 16, 2014 | 06:03 PM
slowsrt4:('s Avatar
or you can purchase the ones from STM that are -6an and they just fit into it with no drilling or tapping.
Old May 17, 2014 | 01:22 AM
Cmax's Avatar
Going to clean really well before and grease up the drill bit and tap. Then clean the hell out of it again. This is with the baffles in.
The -6 AN fitting on the side doesn't breath enough. =(
Old May 17, 2014 | 11:00 AM
michaelrc51's Avatar
Just be carefull, the side that doesn't come with the breather fitting will accumulate a lot of oil if you don't add some baffling.
Old Jun 13, 2014 | 01:36 PM
Paul Walkin's Avatar
Add baffling to the valvecover...?
johnn
Jan 7, 2017 01:16 PM
BonsaiScott
Dec 19, 2016 04:26 PM
hydro334
Oct 20, 2016 04:44 PM
hastievo8
Aug 14, 2015 02:21 PM
jason42003
Oct 14, 2014 01:24 PM
