Starting issue need help!!!
Old May 22, 2014 | 12:08 PM
PhantomBlackEVOX's Avatar
Veteran: Army
Okay so I left work, It ran perfect started right up no issues on the drive home. I go out about an hour later..car is completely dead. I jumped it...ran perfectly fine again until I shut it off. Back to square one when i tried starting it again. I checked my connections the positive terminal can slide around the post a little bit but cant be pulled off....could that be the whole issue im having? or could it be the battery or alternator?????
Old May 22, 2014 | 12:37 PM
meckert's Avatar
any slipping electrical connection is not a good one.. fix that first..but it sounds like you need a battery
Old May 22, 2014 | 02:23 PM
Bhsj13's Avatar
battery. fix the connections.
Old May 22, 2014 | 03:06 PM
EVO KNVL's Avatar
If you fixed the connection or replaced the battery and still have this issue, check your starter. I recently had this issue. I have no issue when it's running but sometimes when I shut if off and try to start it, it wouldn't. Checked the starter and it was bad.
Old May 28, 2014 | 07:53 AM
Veteran: Army
Okay so it ended up not being the terminal connections but my battery posts going into the battery are loose and will not tighten...im assuming my battery is just smoked and i need a new one.
Old May 28, 2014 | 08:09 AM
Reborn624's Avatar
https://www.evolutionm.net/forums/ev...ied-fixed.html
Old May 29, 2014 | 05:19 AM
Veteran: Army
I'm going to look into that when I'm out of work. Same exact issue with the click ill let you know how it works!
Old Jun 2, 2014 | 12:12 PM
Veteran: Army
okay so that did not work either...back to replacing the battery
Old Jun 2, 2014 | 03:38 PM
canfixany's Avatar
Do you have access to a multi-meter or a volt meter. Start the car and disconnect the battery. Measure the voltage from the alternator at the battery cables when the car is running make sure it's supplying more than 12V. Hook the cables back up let the car run for awhile, then disconnect the battery after the car has ran for awhile. Measure across the terminals should be around 12v. If those are good then it's your starter, probably just the solenoid that engages the starter. I know on some domestic cars you can just replace that, never had to mess with the starter on my Evo's though so I don't know. If that is the problem I would see if you can just get the solenoid instead of the whole starter definitely a lot cheaper route. If you disonect the battery, when the car is running, and the car dies you have a bad alternator.
Old Jun 3, 2014 | 09:32 AM
EVO KNVL's Avatar
You really shouldn't be disconnecting your battery terminals while the car is running. This could cause some harm to the electrical system. If you want to check your alternator you can do the following. While the car is off, check your battery with a voltmeter. If it reads 12.2 V or above, it should have enough power to start the alternator. Otherwise, charge the battery until it reads over that. Then start the car and leave it running. Check the battery with a voltmeter again. The voltage should be between 13-14.X volt for a good alternator. If you get the same reading as when if was off or if the voltage decreases, then you have a bad alternator.
Old Jun 5, 2014 | 06:15 PM
intj123's Avatar
A fully charged lead acid battery should read 12.6 volts when charged 100%.
The Evo alternator puts out 14.4 Volts COLD(or if really really cold 14.5 volts)
And fully warmed up and hot it's about 13.5V at the hottest, if it's somewhere in between cold and hot, like just idling warmed up in average ambient temps 70F-85F, should be about 14V flat.
Autozone/auto stores do free battery testing as well. You don't have to remove the battery from your car to test it.
12.0V - 12.2V on your battery means it's almost dead, when a battery is discharged heavily to this point, it will always be running at a reduced efficiency even after recharging the battery.
Old Jun 6, 2014 | 10:27 AM
Veteran: Army
Autozone tested it..came back replace battery couldnt even get a read off it i guess...but I ordered another small batteryf from STM should be in today. I'm hoping thats all it is..if not back to square one.
EkS
Lancer Tranny/Drivetrain Tech
35
Apr 20, 2024 04:36 AM
Wiznaz
10
Mar 17, 2016 11:25 AM
AutoXMRIX
Mar 9, 2016 07:02 AM
RedLeader024
Lancer Troubleshooting
Jun 11, 2014 07:00 AM
SilverLanEvo
Jul 5, 2011 10:52 AM
