Burning oil problem
Old May 31, 2014 | 10:44 AM
eisnikesb's Avatar
Burning oil problem
So I have a burning oil problem I did a compression test the other day and they were 135 140 135 145 so I don't think it is my rings. I checked my intercooler piping on the intake side and it was clean and it only seems to do it on start up and idea is they anything you guys can suggest I do before I take it to a shop
Old May 31, 2014 | 02:28 PM
2slow4now's Avatar
Bad valve stem seals? Maybe your pushing oil through a sticking pcv valve from the crank case?
I would look at the pcv system first since you can probably work on it yourself. Check the simple or easy stuff first.
Old May 31, 2014 | 02:40 PM
bdonIX's Avatar
turbo seals? how many miles/what turbo you running?
Old May 31, 2014 | 03:58 PM
eisnikesb's Avatar
I'm at about 77k and I'm pretty sure the stock turbo would I just take the turbo off to check if it's the seal
Seifer780
Lancer Engine Tech
Sep 22, 2015 02:50 PM
febs1011
Sep 4, 2015 03:28 PM
SeahawksOilers
12
Apr 26, 2014 09:11 AM
TheeVOoNE
Jun 24, 2004 05:16 AM
evoracerx
Jun 13, 2003 06:23 PM
