Ac clutch replacement? Or is entire compressor needed?
Well I diagnosed that the AC clutch on my compressor has to be lightly tapped to engage it, but even after engagement it will still slip. You can see it trying of course. I can feel the magnetism when the A button is pressed on so I am sure the clutch is just worn out sadly.
I was wondering if the clutch components can be replaced, or if a new compressor must be used. I like that I have zero leaks in my system and would love to keep the refrigerant in the system and not have to recover it and refill. If anyone has information or tips to this I would greatly appreciate it.
Hope you all have a great day.
Honestly, you are going to save time and money just replacing the whole compressor with a used one.. I am sure you can get one for cheap on the classifieds. In order to service it you need
A mess of special tools and parts to set it up correctly. I know it is a pain to recover and recharge but its way more of a pain to replace the clutch in it.
I would do it that way and then check the oil and inspect the orifice tube.
I doubt you would have to replace your whole compressor. The clutch components can be replaced without needing to drain your refrigerant. While researching my own A/C related problems, I've come across alot of different people with the same symptoms as you. It seems to be a fairly common problem. From what I can remember, others have fixed it by adjusting the airgap. Mitsubishi sells a service kit with different shims to adjust it. This was a very helpful thread for me: https://www.evolutionm.net/forums/ev...ng-advice.html
I recently had A/C problems and ended up replacing my compressor clutch. OEMMitsubishiparts sells the compressor clutch for $66.97. Replacing it was pretty straightforward, taking me about 1.5 hours without any special tools (although I would recommend a puller).
Hope this helps,
Kyle
Hope this helps,
Kyle
Hope this helps,
Kyle
Hope this helps,
Kyle
Anyone ever have to not use a shim? everything seems to be good now, I will most likely one day replace the two components anyhow.
I actually just this past weekend removed the shim to get my air gap back to spec and get my ac working again, I remember reading of a couple others that also had to remove their shim completely
^^same here, I removed shim completely and got my AC clutch work again. Its second season since removed and no problems so far. Its like 20mins of work. Its worth to try before throwing money at it. Good luck.
JB2003OZ
Lancer Troubleshooting
Jun 26, 2013 06:41 PM
jxs1984
20
Nov 2, 2010 05:46 AM
