Evo 9 Prob Help!
Old Jul 19, 2014 | 06:35 AM
Brian9rs's Avatar
Evo 9 Prob Help!
Soi just finished doing a pull in 3rd gear so i shift into 4th normal and i give it gas and the throttle starts shuddering and it started choking upon giving it more throttle i slow down and down shift and it seems to be cathcing the gas again then starts choking upon more throttle again i drove my var home in first gear any ideas on what it could be?
PS. The car still starts fine and can still be tooken out of first gear decently. I also wanted to mention that i upgraded the fuel pump to a warlbro 255 lph.
Old Jul 19, 2014 | 08:50 AM
Bhsj13's Avatar
bad spark plugs maybe? maybe needs a tune?
Old Jul 19, 2014 | 08:52 AM
Bhsj13's Avatar
can you give a full list of mods?
Old Jul 19, 2014 | 09:52 AM
evo8426's Avatar
Probably a big boost leak
Old Jul 19, 2014 | 11:44 AM
twabtoxer's Avatar
What kind of plugs, Injectors and fuel are you using?
Old Jul 19, 2014 | 12:30 PM
3SgteGuru's Avatar
Big boost Leak, IE popped off ic pipe.
Old Jul 19, 2014 | 04:38 PM
Nohatn's Avatar
im thinking leak. check your pipes. mine did that also was the intake from turbo to filter.. was just a little loose. let us know
Old Jul 19, 2014 | 05:05 PM
Brian9rs's Avatar
sorry took me so long to respond i thought it was my fuel pump because i upgraded it to a warlbro 255 lph and ran it like that for at least a month with out a tune. i put my stock pump back on and still have the same problem.
mods are megan racing turbo back cobb sf intake and i have bosch 1000cc injectors which i havent installed because i was saving money for e85 tune and stage 2 clutch kit with act streetlite flywheel
Old Jul 19, 2014 | 08:31 PM
slowsrt4:('s Avatar
change your spark plugs, check your intercooler piping and do a boost leak test
Old Jul 20, 2014 | 10:04 AM
Brian9rs's Avatar
Thanks Guys !!!!!
problem was that the lower inter cooler piping was split in half anyone recommend an good brand aftermarket piping kits so i can replace it with?
izabran
Jan 30, 2016 09:27 AM
Eisen7
Nov 10, 2015 01:51 PM
Kaveeth
Mar 20, 2015 12:38 AM
plastus
Mar 16, 2014 06:46 PM
BruteEVO
Feb 16, 2014 06:13 PM
