Question re:Methanol/Water Injection, HELP!!
Old Aug 8, 2014 | 07:04 AM
sundevil79's Avatar
Originally Posted by 9evolution
Im not sure if im reading this correctly. You should have a seperate tank elsewhere in your car for the 50/50 mix. The mix does not go in your fuel tank. I have a aquamist kit been using it for 2 plus years i have a 2.5 gallon baffled tank in the trunk. I have used less than 8 gallons in two years. Mine is triggered by injector duty cycle not boost and progessivly sprays more as the duty increases. If you drive like a nut you obviously will use more juice. A good meth system will have a failsafe as well, to lean or no spray it will dump the boost therfore saving your engine.
UPDATE: OK so i bought the vehicle. Turns out he has been running M1 Methanol straight 100%, no mixture. Yesterday I noticed my first "issue". Was coming down on an offramp and noticed the rear end and white smoke dumping out of the exhaust. Thought maybe, "it cant be coolant" levels were fine, no indication of blown head gasket. wasnt blowing smoke all the time (not like this). Went away after 10 seconds. RPMs dropped to about 800 and AFR was about 10.5. but cleared up.
Today, same thing in the exact same stretch of road only this time, the car bogged down so much that it was around 2-300 rpm. Car shut down. I pushed off to the side of the road, turned off the switch for methanol, started up and it ran at 200 rpm. I let it run, pushed the throttle cable a bit and it bumped to around 600, waited 2 mins, pushed the cable again, bumped back to 1000. If I would have to guess, it flooded the intake with too much, (which might explain my rapid depletion of methanol in the fill tank, [dial setting 1-8, which he had at 8]). Let the car sit for another 7 mins and drove away, no white smoke ran fine. about halfway to work, i turned back on the pump and turned the dial to 4 instead.
Pretty sure im gonna remove this thing, I need something more reliable than this like.... NOT running meth injection. Anyone else agree? no? thoughts?
Old Aug 8, 2014 | 12:23 PM
9evolution's Avatar
What kit is installed? Personally i would remove the system and replace with an Aquamist kit. For no other reason than its a rock solid piece. I'm not an expert by any means but i believe that 100% is not good for a number of reasons. Its hard on grommets, seals and pump parts.
Old Aug 8, 2014 | 01:11 PM
sundevil79's Avatar
ALKY Injection system. http://www.alkymethinjection.com/
I currently have the toggle turned down to 4 on its 1-8 dial setting. I spoke with Dave, the previous owner, and he said, he normally ran it at 6 but it may have been nudged in the glove box because of his storing the car at winter last year. (its only got 29,500 miles on the car) but that he also lowered the manual boost control and that that may have potentially also affected the intake of methanol? I guess that might make sense, but i think at this point im considering rmoving the system altogether. I use it as a DD and really dont care about racing it. I'm 35 and I just want reliable (but fun) transportation around. (low maintenance) I would consider the aquamist or snow performance but my time is limited in removal and install of a new meth system and I do almost all my own work. Only realy way to get to learning i feel. But since I dont have thousands of dollars to mess around with blown engines and gaskets and whatnot, I havent decided yet. If i can fix this problem and reduce my methanol intake, i'll be happier.
Old Aug 8, 2014 | 02:03 PM
Ev0ikon's Avatar
You should not *****-nilly change the meth volume like that. Remove it or you will be replacing the Engine block soon. Too much spray will wash and wear down your piston rings in a hurry.
esevo
43
May 31, 2015 05:55 AM
scheides
271
Jan 6, 2013 10:06 AM
project_skyline
Sep 13, 2012 11:50 AM
BCOZEVO
12
Oct 19, 2009 09:02 PM
icedomin8r
Sep 19, 2006 04:00 PM
