Evo 9 build
Old Aug 10, 2014 | 10:06 PM
Evo5950's Avatar
Evo 9 build
I'm looking to get about 450hp outta my evo 9 . What should I do ? I'm trying not to build the motor maybe even under 450 will do . But I'm thinking about a fp black maybe some cams? I'm not sure. I have a greddy ti exhaust n a qtp cutout but that's it plzz help
Old Aug 10, 2014 | 11:45 PM
shrtstuff89's Avatar
Fp red
Walbro 450 fuel pump
1450+ cc injectors
Throw in some head studs for safety, and 20-23psi should do you just fine
Cams & springs/retainers will help you in the mid-high rpm range (where the red shines at) but not required
Old Aug 11, 2014 | 12:20 AM
slow gst's Avatar
These threads start 3x a week at least. It definitely took you longer to make an account then it would to just google your question. But since we're already here, for the 5,000th time, here you go. http://bit.ly/1ylP8uK
Old Aug 11, 2014 | 05:13 PM
Evo5950's Avatar
Originally Posted by shrtstuff89
Fp red
1450+ cc injectors
But I don't want to use e85. Will I need to add more stuff or no?
Old Aug 11, 2014 | 05:58 PM
Biggiesacks's Avatar
with no e85 you will definitely need an intercooler upgrade to support that power level. Boost controller either 3-port or MBC. You will want to install a wideband, and either a 3-bar or 4-bar map sensor. LICP will be a must UICP will help as well. The things others have already mentioned as well. Also the OEM clutch will not handle that power. so a new clutch will be in order.
Cadmonkey
Sep 30, 2014 07:53 AM
Evo5950
Sep 29, 2014 04:20 PM
jrosario8383
11
Aug 18, 2014 12:45 PM
(03evo08)
Aug 10, 2014 03:03 PM
Markourn
10
Dec 19, 2006 12:09 AM
