IX Rear Diff Question
Old Aug 20, 2014 | 05:21 PM
blueprint's Avatar
How many bearings are in the rear diff of our cars and what are the part numbers? I am in the process of rebuilding mine with the Weir 12 plate but i figured since im in there i can refreshen things up.
What else should i do with the rear diff while it's out of the car.
Old Aug 20, 2014 | 05:58 PM
meckert's Avatar
Do you have the tools to setup a diff? I assume you know you cant just pull the bearings and then re-install knew ones without checking and resetting tolerances and reshimming. I would be a little concerned with the pinion bearing due to the low fluid levels of the stock diff cover running that bearing a little low on fluid from the factory...other then that you should be good to go.
Old Aug 20, 2014 | 09:10 PM
blueprint's Avatar
I seriously didn't know that... i assumed you can just remove them and replace with a new one.... i read about the pinion bearing and i have a feeling mine may be going out as i hear a grinding noise coming from my rear diff on deceleration and a whining noise on acceleration in the highway.
My mechanic also confirms it's coming from the rear diff although when i changed the fluids today there was no metal in the magnet drain plug nor any metal fragments in the fluid.
Old Sep 7, 2014 | 06:31 PM
3gturbo's Avatar
Send it to shep and have it done right.
Old Sep 7, 2014 | 06:35 PM
kyoo's Avatar
Originally Posted by blueprint
i seriously didn't know that... I assumed you can just remove them and replace with a new one.... I read about the pinion bearing and i have a feeling mine may be going out as i hear a grinding noise coming from my rear diff on deceleration and a whining noise on acceleration in the highway.
tre
Old Oct 12, 2014 | 07:18 PM
Colorado Sparky's Avatar
Diff plates are easy. I rebuilt mine 2 times a season for 4 years. I wouldn't do the bearings until it is needed. You will need a press and specialty tools. Plus you will need to re-shim the diff. If you only rebuild the plates you don't have to reshim the diff.
Old Oct 16, 2014 | 04:18 PM
blueprint's Avatar
Upgraded to the Wier Max Grip LSD and changed out all the bearings. She is as good as new now.
Old Oct 16, 2014 | 04:24 PM
jfa_evo's Avatar
so, what was the problem? Diff plates?
Old Oct 16, 2014 | 11:07 PM
blueprint's Avatar
To be honest... I didnt see anything wrong with the plates or bearings. I replaced them all however and the noise went away. Using Redline fluids this time vs. the stock diaqueen.
Old Oct 17, 2014 | 12:09 AM
evobros's Avatar
Did you setup the rear diff JDM style?
GSX_TO_EVO
Aug 29, 2016 02:55 PM
EvoJoeRacing
38
Aug 20, 2011 07:16 AM
maximusnz
Sep 28, 2009 05:52 PM
raywong
13
Nov 18, 2003 08:18 AM
