Engine break up at WOT
Old Aug 31, 2014 | 07:46 PM
PaEvo's Avatar
Hypothetically speaking, I might be racing a zr1 and I pulled in 3rd, pulled hard through 4th and pulled through 5th but encountered problems around 6k. Running 2.3 3586hta on 93. Gas was garbage. In 5th I started breaking up around 6k WOT and the engine started to pull timing and the wastegate (tial 44) starting popping. Needless to say, this (May have) happened, the zr1 crushed me at 120mph. I running stock ecu iridium one step gapped .24. Time for coil on plug? Never had problems wot. I'm running SD and was running uphill and made an elevation change to make the ears pop. Time for COP?
Old Aug 31, 2014 | 07:58 PM
blueprint's Avatar
Knock maybe since your on **** Gas??
Old Aug 31, 2014 | 08:08 PM
PaEvo's Avatar
That's my guess. The 92 may have been 89
Old Aug 31, 2014 | 08:23 PM
Bhsj13's Avatar
bad gas.
Old Aug 31, 2014 | 08:24 PM
czum09's Avatar
.24 is too large of a gap for anything past stock boost. Gap the plugs tighter. Mine are .19. Spark plugs could have been blowing out.
Old Aug 31, 2014 | 08:56 PM
blueprint's Avatar
The bigger question is.... Why aren't you on E85??
Old Sep 1, 2014 | 06:33 AM
czum09's Avatar
E85 ftw!
Old Sep 1, 2014 | 07:03 AM
Ev0ikon's Avatar
Get a new set of plugs and gap em down to 0.020"
Then "hypothetically" go ZR1 hunting .
Hope nothing bad happened.
Old Sep 2, 2014 | 02:55 PM
PaEvo's Avatar
I'm getting a noncdi cop and e85 in the next couple of weeks. I'll be back in the hunt. Looks like 5th gear wgdc were never set. Was only tuned through 3rd
MRLancer05
Jul 27, 2016 03:52 PM
fenriq007
15
Jan 12, 2010 10:57 AM
chriswolf81
Dec 4, 2009 09:58 PM
rACerS
20
Feb 8, 2007 09:19 AM
althemean
31
May 2, 2006 12:20 PM
