help: t case, or transmission leak?
Old Sep 6, 2014 | 02:15 PM
evocamas's Avatar
Hello everyone, I am new here and recently bought a stock 2005 evo 8 with a 2 month old clutch. I noticed some leaks by the driver side/transmission area. The axle that goes into the transfer case is free of leaks, but I see that its wet/oily where the t case and transmission meet. I attached some pics. Much appreciated, thanks!
Attached Thumbnails help: t case, or transmission leak?-20140906_132518.jpg   help: t case, or transmission leak?-20140906_132423.jpg   help: t case, or transmission leak?-20140906_132843.jpg   help: t case, or transmission leak?-20140906_133330.jpg
Old Sep 6, 2014 | 03:57 PM
shavkatjon2000's Avatar
what i would do is get a brake cleaner and clean everything out the wet spots and check day or two later to see where is its wet again yours is just a wet no major leak that's the best way to find out
Old Sep 6, 2014 | 05:33 PM
evocamas's Avatar
That's exactly what I did, I cleaned it up and that's the leak from two days later. I just don't know what to replace or fix. Thanks for the advice!
Anyone else have the same problem? Maybe whoever did the clutch messed up on something small.
Old Sep 7, 2014 | 06:59 PM
D1andonlyantman's Avatar
I bought my evo a few months ago and it had had a new clutch not too long ago and I had a leak around there. Maybe coincidence, maybe not. Anyway, there are 3 seals on the transfer box so I thought it was one of them, but after my mechanic mate done some digging it turned out it was the o-ring the goes on the outside of the seal between the transfer box and gearbox (If I remember rightly). Let me know if you want the part number, I think I've still got the receipt around here somewhere
Old Sep 7, 2014 | 07:58 PM
evocamas's Avatar
Thanks! I could use that part number if you don't mind. Is it something I can fix in the garage or does it require a shop to take apart my transmission?
Old Sep 7, 2014 | 08:07 PM
I'll need to have a look in my paper recycling for the receipt in the morning (it's 4am here now) but like I said, there are 3 main seals on the transfer box and then this spring loaded o-ring that goes inbetween the gearbox and transfer box, so if you ring mitsubishi they should know what you mean. I'll let you know if I find it though. They only cost me a few quid per seal so if I were you I'd just buy all of the ones near the leak to cover all bases and minimise car downtime. Assuming it's one of them seals it just an on the ramp job. I don't think he had to remove the subframe either
Old Sep 7, 2014 | 08:25 PM
Turns out I didn't bin it. I guess it's the same part number for your 8
The number is: MD727944
I hope that helps
Old Sep 7, 2014 | 09:04 PM
xXANCHORMONXx's Avatar
Looks more like an oil pan leak...
Old Sep 7, 2014 | 09:28 PM
TommiM's Avatar
Looks like engine oil to me. You can try putting in dye in the transmission, clean everything up, and see if the fresh fluid leaking has the dye. If its not, clean it up again, put dye in the transfercase and repeat. If the new leak has the dye, then you know where it came from and can concentrate on that. If not, then move on to the engine oil, and so on.
Old Sep 8, 2014 | 01:38 AM
evocamas's Avatar
Thanks guys. I know the oil pan has a small leak for sure, which will be fixed soon, but when I cleaned everything down there the leak still came from the transmission/driver side area. I'm guessing the gasket/seal went bad. What do you guys think?
eddy5201314
Apr 21, 2017 06:34 PM
aviseevuoptical
Feb 28, 2016 12:24 PM
yenny
21
Sep 12, 2012 11:28 AM
memphis raynes
10
Jul 9, 2012 04:04 AM
BEKevo
11
May 6, 2012 07:29 PM
