AC buttons
Old Sep 7, 2014 | 05:29 PM
pistons4550's Avatar
AC buttons
I just bought my IX MR about a month ago and some of the only things that dont work are two of the AC buttons. The AC button itself is stuck on ON and the air circulation button is stuck on ON. Im wondering if the circulation button being constantly on could cause drag since air from the outside is getting into the cabin. Also a side question, does the usdm stock radio have a backlight?
Old Sep 7, 2014 | 06:21 PM
nk1124's Avatar
if you have the temp dial set all the way counterclockwise to MAX A/C both those buttons will be stuck on, have you tried turning that and seeing if they are still stuck on?
Old Sep 7, 2014 | 06:31 PM
lol wow I feel pretty stupid, thank you very much
Old Sep 7, 2014 | 08:10 PM
novem's Avatar
The three buttons in the middle. The first one going left to right is the rear defroster. Center button is the AC , and third is to vent outside air. If you have the rotating dial on the left all the way down to Max AC, the AC will be on if you press the center button on or not. The vent button will also default to closed with the Max AC dial selected weather the buttons light up or not. Move the dial off Max AC to the blue dot and the selector buttons should function individually !
N.
Old Sep 8, 2014 | 05:45 AM
Sweet, I wouldnt have known they worked until I had to use the heater lol. Does anyone know if the radio has a backlight? If it does, it will be the only thing that doesnt work on the car.
CeeKayy
Jun 9, 2013 11:22 AM
eTiLiKo
May 23, 2012 05:45 AM
nosreme722
Lancer Troubleshooting
Feb 8, 2012 10:57 PM
Thoe99
11
Jul 8, 2003 06:17 AM
