Horriffic Vibration while engaging clutch
Old Nov 12, 2014 | 06:51 AM
  #31
flippymcbean's Avatar
I'm going to take it apart next week. Just picked up a small air compressor and an impact. I got a few more jack stands and 2 jacks... Almost ready to tackle this.
Old Dec 18, 2014 | 05:02 PM
  #32
So I finally pulled my transmission.
Here are the pictures.
Throw out bearing is broke, and the wave spring think and spring clip all need to be replaced. No idea what clutch I have. I'll look at it tomorrow.
Old Dec 18, 2014 | 07:00 PM
  #33
Also can anyone tell me what kind of clutch this is? I wanted to order the ACT Monoloc Collar because I was told the car had an ACT Clutch kit. So far I don't believe it.
I'm going to pull the cover off tomorrow...can I still order the ACT Monoloc collar for this random pressure plate?
Old Dec 18, 2014 | 08:08 PM
  #34
06mr775's Avatar
That is not an ACT clutch. It looks like an exedy or a Competition clutch. Pull the pressure plate and see what the disc and flywheel looks like.
Old Dec 19, 2014 | 11:12 AM
  #35
I dont have the stupid clutch alignment tool, and i have to order one. I should have ordered prior to this. I might as well get a new clutch while this is off. This clutch has about 1400-1500 miles....though. Kind of in a pickle....
Old Dec 19, 2014 | 01:15 PM
  #36
S.Brewer's Avatar
FCOTM Winner
Something tells me that tape over the turbo inlet is not helping
Old Dec 19, 2014 | 03:04 PM
  #37
just creating a nozzle to raise air velocity into the turbo.
Old Dec 19, 2014 | 04:02 PM
  #38
robbyredneck's Avatar
Old Dec 26, 2014 | 10:54 AM
  #39
Can anyone tell me how bad this really is?
It looks bad, feels fairly smooth.
Old Dec 26, 2014 | 01:57 PM
  #40
Ev0ikon's Avatar
The Flywheel will need to be machined and only after that you could determine if it is still usable. I would replace everything else.
Old Dec 26, 2014 | 02:42 PM
  #41
Thanks. I guess I'll just replace everything. Not even bother with the machining process.
I've been looking at Clutches and probably going to get the Exedy stage 2 with the exedy flywheel.
Still thinking about the exedy Hyper Single Clutch...that may be over kill though...haha. Only because the flywheel is part of the kit.
Old Dec 28, 2014 | 01:46 PM
  #42
S.Brewer's Avatar
FCOTM Winner
I have a great condition exert light weight flywheel in not using. Came with my car. Lmk of you want pics. Still have my #?
Old Jun 17, 2016 | 11:40 PM
  #43
ilango pillai's Avatar
Engine vibrates when shifting gear
I have some horrible shaking/vibration with my car. Just recently started a few days ago. It was on and off, but not its all day everyday
For example, If I'm and a stop sign or stop light and i slowly engage with while giving throttle, it vibrates like crazy. It does the same thing in reverse as well. I looked through the inspection hole, and everything seemed fine.
I just put a new exhaust on my car and currently have my "underbraces" that were underneath off because I just ordered the cusco ones. for down pipe clearance, but could this be a possibility?
Could I adjust my clutch?
I've read a few things saying its the clutch itself, but they all had twin disks. I have a Stage 2 ACT clutch(CRAP!)
Any suggestions on what it is? How to fix it? Thank you!!
Hello I m not sure u sorted out the issue wit ur engine vibrating while engaging clutch ?! My guess is that can't be a clutch sometimes its turns out to be the harness which connects to the TPS throttle position sensor ..may be it could ve loose contacts or oxides ...its job is to send signal to ECU and vice versa ! And keep the engine Rev steady for any kind of load we give to the engine or so...so just check with the harness just clean it n reinsert it ...disconnect the negative terminal of battery b4 doing it so that it need not hav to be reprogrammed ..memory stays ...happy driving..!
Old Jun 18, 2016 | 11:14 AM
  #44
barneyb's Avatar
Just throwing this out there, but my chassis underbraces are off the car. I didn't get a chance to make it to lowes for washers for a temp fix.
Do you think that this could be a possibility?
That is a bad looking clutch. Time for replacement.
chrisff521
24
May 5, 2012 12:27 PM
evosevengsr
Dec 11, 2004 08:50 AM
darkjediii
Jul 20, 2004 07:24 PM
snoop
11
Feb 26, 2004 10:36 PM
