What Oil to use with e85
Old Oct 15, 2014 | 09:22 PM
evole97's Avatar
fp red.. kelford 272.
Old Oct 16, 2014 | 03:31 AM
05EV08's Avatar
Motul 5w30 I've used it in every one of my cars with no issues at all.
Old Oct 16, 2014 | 04:29 AM
gsrboi80's Avatar
Pick an oil, send it for UOA after a few thousand miles, then you'll know how said oil is doing in YOUR motor, adjust you OCI accordingly
Don't worry though the AMSOIL fanboys will be here 3....2....1 telling you thats the only oil you should ever use
Old Oct 16, 2014 | 07:14 AM
apagan01's Avatar
Zrod 10W30
apagan01's Avatar
He maybe smarter than you and he may look at the ZDDP, TBN to ensure it handles how the ethanol dilutes the oil faster... sending in a sample is reacting after an issue is there and not being proactive.
Old Oct 16, 2014 | 09:27 AM
boostedinwyo's Avatar
rotella 5 40 synthetic here
Old Oct 16, 2014 | 10:37 AM
andrewzaragoza's Avatar
since you are on fp red and if your red is still under warranty I would suggest using one of their recommended oil. for me I have been using rotella t6 for about 3 yrs on e85.
Old Oct 16, 2014 | 10:51 AM
e_kobz's Avatar
I just switched to Penrite 10W-40 Racing oil. It's designed for the use of E85. I absolutely love it
Old Oct 16, 2014 | 03:07 PM
blackangel42's Avatar
doesnt really matter to much..use whatever u prefer ..just needs to be changed a little more regularly sence e85 breaks oil done more then regular gas.
Old Oct 16, 2014 | 09:49 PM
ID #376's Avatar
I use Shell Rotella 15W-40 Heavy Duty Motor Oil for the winter & I use Valvoline VR1 20W-50 in the spring summer & fall. Then again it's a preference & learning what works well with your car & set-up. I'm running E85 2.1 high compression motor so I change my oil every 1200 mile so I keep it simple. The Valvoline VR1 is high in zinc which is good for your internals.
Old Oct 16, 2014 | 11:05 PM
blueprint's Avatar
Eneos 5w40.
Old Oct 17, 2014 | 10:22 AM
Noize's Avatar
EvoM Administrator
gsrboi80 trolling revision 1000 = Two weeks account disabled.
To the OP: In Cali, I would run Mobil 1 10w30 year round. I run 5w30 here when it gets cold. Just change oil sooner than on pump gas. Good luck!
Old Oct 17, 2014 | 11:23 AM
Biggiesacks's Avatar
Any oil that has an API GF-5 or SN rating is suitable for use with E-85 and turbocharged applications. From API's Oil standards guide the description of GF-5 certification is as follows:
"Introduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons and turbochargers, more stringent sludge control, improved fuel economy, enhanced emission control system compatibility, seal compatibility, and protection of engines operating on ethanol-containing fuels up to E85."
Link: http://www.api.org/oil-and-natural-g...10_120210.ashx
I personally use Mobil 1 5w-30, I have been running E-85 for 5 years and have had 0 problems.
ryukinevo
14
Aug 11, 2011 02:47 PM
chaoschink
64
Jan 22, 2007 11:22 AM
