Car cranks...Cranks....Starts...Then Wtf??
Hello
So as of yesterday morning my car has been acting strange... I start the car and seems like every morning or after car has not been driven for maybe 7 hours I try and start the car and it cranks for a bit then I hit gas then it finally starts..
Car starts vibrating more than usual, UEGO AFR Reads 16.0 then all of a sudden goes
" ------- " and just stays like that.. I hit the gas an the pedal feels heavy. Once the car WARMS UP. Car runs fine and idle goes back to around 14.2-14.9 bouncing around those numbers..
I am running e85. Also my service engine light had come on with code "P0134" I did reset the light and it has not come back on..
What the hell is going on with my car? Ever since I upgraded all my parts its like HELL
^^^Sounds like you need to modify the cold start table in the ECU. My tuner adjusted mine after converting & now it fires on the 1st or 2nd crank during the winter
https://www.evolutionm.net/forums/e8...ps-tricks.html
Add the tables in this thread: https://www.evolutionm.net/forums/ec...cv-tables.html
It will be the tables labeled 1 & 2 for fuel is what you will use the most. Start adding fuel until you're happy with the start up. e85 takes a lot more fuel than most people think it will, especially on very cold mornings. Follow the instructions in that thread and you'll be good.
Thank you to all of you guys.
I was thinking of grabbing a match and throwing it in the gas tank too warm the fuel up a bit before cranking the car. Or dropping warm water in there. Cause this **** is annoying an embarrassing at times feels like im driving a Honda when I crank at a restaurant or something.
evolancer04
Apr 27, 2011 12:58 PM
joel(PA)
23
Mar 25, 2011 10:26 AM
