E85 cold start tips and tricks
Old Nov 14, 2007 | 08:55 AM
EVIL_EV0's Avatar
Question E85 cold start tips and tricks
I've got about 2k E85 miles under my belt. But recently the temps have been dropping and the car takes a few more cranks to pop off.
Does anyone have helpful hints for getting an E85 powered car to start on the first try during a below freezing start?
Old Nov 14, 2007 | 11:50 AM
hokiruu's Avatar
Based on the fact that you said you have 2k mi. on the car since you switched over to E85 and given the time of year, it seems possible that you are tuned for true 85% E85 and the stuff you're now getting at the pump in this season is actually 70% Ethanol/E70.
Are you still running a 85% Ethanol tune? Or are you experiencing this after already re-tuning to compensate for the reduced Ethanol content? I've heard cold temps make it a little harder to start on E85, but if you are still on the 85% tune, this probably contributes to it as well.
Old Nov 14, 2007 | 12:28 PM
hokiruu's Avatar
check out mplspilot's post a bit down, he said it strts right up at 40*F...
https://www.evolutionm.net/forums/sh...d.php?t=295050
Old Jan 22, 2010 | 08:52 PM
ace75's Avatar
bump for more current info on this.
Old Jan 23, 2010 | 04:54 PM
Jim in Tucson's Avatar
This might be helpful: https://www.evolutionm.net/forums/7745462-post6.html
To implement you will need to upgrade to the 96530706 Tephra v7.0 ROM, or add XML for the IPW adder to your existing ROM.
There is only 15% gasoline in E85. Gasoline is what fires off your engine, so you need a bunch of E85 in order to have enough gasoline to fire off.
Old Jan 23, 2010 | 05:05 PM
todd6027's Avatar
think its an evo9
Old Jan 23, 2010 | 07:01 PM
Jim.......With your suggestion I had my tuner add the tables to V5.1 & it has helped......It takes approx 2-3 (2) second stints to get it to fire....Does that sound OK for the mild temps here in So.Cal (Morning 48 degrees)???
Thanks, Joe (BTW, What about that Rain event =)
Old Jan 24, 2010 | 06:16 PM
My VIII has been firing off on the initial spin of the starter with temps as low as 40F. I suggest you simply try increasing the IPW adder settings a bit more.
In fact I've increased mine a bit since I posted in the 96530706 thread.
Here is what I'm using right now:
-26=361
0=240
18=150
45=80
68=45
93=14
122=8
171=7
180=7
Old Jan 24, 2010 | 08:14 PM
^^^Thanks Jim.......Copied......Will send info to my Tuna............Joe
Old Jan 27, 2010 | 12:52 PM
GST Motorsports's Avatar
Needs more IPW
My personal Evo 8 starts first crank after shoveling it out of snow at 18-20F mornings in Tahoe:
Old Jan 27, 2010 | 02:24 PM
Bryan, what is that white stuff all over your EVO? I've never seen that in Tucson!
All i can say is WOW!
Old Jan 27, 2010 | 02:30 PM
whiptheevo8's Avatar
This looks all to familiar to me..
Old Jan 27, 2010 | 02:45 PM
Hahha, here is another one from last week with my new "aero"
Old Jan 27, 2010 | 03:55 PM
mrfred's Avatar
So this is where you're at when you're not tuning Evos?
Old Jan 27, 2010 | 03:59 PM
boostedwrx's Avatar
Hehe your Evo doubles as a snow plow dude
