AEM Failsafe Gauge install *help*
Old Dec 20, 2014 | 04:26 PM
12WWGSR91's Avatar
Hey guys so i got the new aem fail safe gauge. I know how to install the gauge it is just the "failsafe" part that i do not get. Its the part when you reach outside the desire afr it will cut the boost. And run wastegate. For anyone running this gauge any help is apprciated thank you.
Heres the instructions
http://aemelectronics.com/files/inst...fe%20Gauge.pdf
The thing i am confused about is on page 16
Thank you
Old Dec 20, 2014 | 09:16 PM
TheBoz's Avatar
When running an EBC the idea is to open the EBC or fully close the EBC depending on how you car is configured. Depending on the wiring you might need to hook a relay up to convert a pull to ground to +12.
How is your EBC setup then we can give you a little more insight.
Old Dec 21, 2014 | 01:17 AM
12WWGSR91's Avatar
Ok so i would need a electricle boost controller? Because i have a hallman boost controller.
Old Dec 21, 2014 | 04:51 PM
TheBoz's Avatar
With the stuff that you are talking about yes. You might be able to hook it in to the stock ECU and configure a failsafe. You can also hook it up to a shift light, ignition box, WMI system, any number of options.
Old Dec 22, 2014 | 09:19 AM
Drifting Away's Avatar
You know you can do this with your ECU right?
Old Dec 23, 2014 | 07:44 AM
12WWGSR91's Avatar
Could you help me out on how to install this with the stock ecu? I have a mbc
superazncat009
Jun 6, 2014 11:17 PM
iLLuZioNSmurF
May 1, 2014 11:07 PM
m0nkie
Apr 23, 2014 09:54 AM
RealStreet
EvoX 'For Sale' Electronics / Lighting / Audio
Jul 25, 2012 09:58 AM
