RPM drops too low/stall when clutch pressed
Old Jan 6, 2015 | 11:11 PM
dtenev2's Avatar
I had the same problem on my 97 DSM and never fixed it. Drove it like that for years. I learned how to shift at what rpm so that it doesn't stall. I would give it a tap of gas sometimes when going into neutral so that it wont stall. I was thinking it could be a BOV issue.
Old Jan 7, 2015 | 09:56 AM
BlackHawk_Tsi's Avatar
could it be carbon build in the throttle body?
Old Jan 8, 2015 | 02:15 AM
hung861988's Avatar
Originally Posted by X Double Dot
No need to pull the thrust out, just do that test I mentioned, would only take a few minutes and would rule it out (or prove it)
Thank you for your input. I will try to test it later on when I have time. Still too busy with work
Old Jan 8, 2015 | 02:16 AM
hung861988's Avatar
Originally Posted by GTijoejoe
Do you have a method to monitor your A/F ratio and timing?
Idle with and without clutch depressed?
Just trying to find what's going on there.
I don't have the AFR gauge at all. I will check with my tuner again to see if the AFR is stable or not ?
hung861988's Avatar
Originally Posted by newbieEVO8
raise your idle speed in the tune
cams are affecting the amount of vacuum
I did raise the idle to 1100rpm but it could not fix the RPM dipping issue.
Old Jan 8, 2015 | 02:17 AM
hung861988's Avatar
Originally Posted by 10isace
Log and post the issue. Show TPS, RPM, AFR, Timing, IPW, ISC Steps, Target Idle, etc.
I don't really have anything to log the car. I always rely on the tuner to help.
I think I may need to purchase the cable and learn to mess around with my car.
Old Jan 8, 2015 | 02:18 AM
hung861988's Avatar
I happened with my plastic BOV, metal BOV (MR version) and also my Turbosmart BOV (Recirculated) as well.
Old Jan 8, 2015 | 02:19 AM
hung861988's Avatar
Originally Posted by D1andonlyantman
Basically what I meant is that it might be possible putting on the new intercooler has thrown off the map a bit, resulting in the idle dipping sometimes. I'm not sure if changing the intercooler is likely to have thrown off the map that badly but seeing as you only changed the intercooler and the clutch, it seems reasonable to think it could be map related.
I have got another tune after the clutch and intercooler replacement but It did not fix the issue.
hung861988's Avatar
Originally Posted by Ev0ikon
Sounds like Crank-walk. Prove me wrong my showing a hi-rez picture of the thrust bearing.
Oh come one, don't scare me
Old Jan 8, 2015 | 02:20 AM
hung861988's Avatar
I have cleaned up the MAF and throttle body - no hope
Old Jan 9, 2015 | 09:02 AM
10isace's Avatar
Did you take off the tb and clean the plate? Don't! You'll have additional idle problems.
Old Jan 15, 2015 | 11:34 PM
hung861988's Avatar
UPDATED GUYS !
Put back the stock rubber intake pipe and it solved the problem. Iddle is super smooth now.
Thank you everyone for your contribution
splitfire
Lancer Engine Tech
Nov 8, 2017 12:56 PM
supak1111
12
Nov 10, 2016 10:17 AM
Randal
Nov 27, 2012 06:22 AM
Oettinger
34
Nov 25, 2008 04:53 PM
