1st gear + Low RPM = jerky / bumpy
Old Dec 31, 2014 | 09:45 PM
wowzers's Avatar
Hi guys,
I guess this has been happening from day 1 but i hadn't really took note until recently.
Say, in a parking lot; in first gear, under 2000 - 3000rpm. The car feels jerky until the rpms increase over about 2,500 - 3,000rpm.
Its kinda embarrassing also.
The cars details are as follows:
2007 AUDM EVO IX with 32,500 Miles on 98RON (93 octane in US) approx 315whp
Stock; turbo, cams & coils.
Aftermarket; ECU & full bolt-ons
Clutch; unknown, possibly still stock.
Ive only driven the car approx 1,860 miles since owner ship this year, so i can't really recall whether the car was like this when it was quieter (without exhaust) or after a Dyno tune.
(the dyno tune wasn't the best, as i believe there is cold starting issues on 93oct, poor economy, back fires on some gear changes & radiator fan doesn't come up till late.)
I have read some cars do this due to the way the transmission is set up/designed.
Can anyone shed some light on this?
Old Jan 1, 2015 | 12:15 AM
babaz7's Avatar
its almost the same with every evo, mine does the same too. its jerky at low rpm's in the first gear, i guess its normal for evos.
Old Jan 1, 2015 | 03:30 AM
wowzers's Avatar
Do you have the stock clutch also?
thanks for sharing, hopefully its normal
Old Jan 1, 2015 | 04:31 AM
jvsc91talon's Avatar
I have the stock clutch and mine does this also. It almost feels like the car is too heavy and just bogs in low rpm. I have to give it more gas than I do in any other car to take off in first.
Old Jan 1, 2015 | 06:55 AM
Taifighter's Avatar
I've had that same issue with nearly every manual transmission car I've owned. They have all been modified performance cars except one, which was a Saturn.
Anyway... if you're rolling in 1st at low RPM, low MPH, clutch disengaged, and you tap the throttle, the car will jerk and lurch. If if you're rolling in 1st at low RPM, low MPH, clutch disengaged, and you clutch in, tap the throttle and then release the clutch like a normal shift, the issue goes away, correct?
Old Jan 1, 2015 | 09:52 AM
vr4gasmtt's Avatar
I had this issue and it was very violent jerking at low rpms. The symptoms went away when I switched back to a stock ix bov( had greddy RS). It still happens just not as often and not as violently.
I drove in a buddies evo w speed density and his car had no problems with rpms dropping or jerking. I wil be going speed density after I figure what is wrong w my evo.
Old Jan 1, 2015 | 07:24 PM
wowzers's Avatar
Nah i have the OEM MR BOV.
i dunno about 'violently'…
yeah low rpms… and i notice that it can do it in 2nd gear also but not as prominent. it has to be low rpm… i noticed that it disappears exactly at 2,000rpm.
well I've got a Mazda 121 daily in manual, and this thing doesn't do it at all! lol
Old Jan 1, 2015 | 07:49 PM
Bhsj13's Avatar
mine only does that when nearing time to change out plugs. also when driving it cold it does this for me as well. when its all warmed up, its good to go with no jerkyness. i heard a COP kit helps with this.
Old Jan 1, 2015 | 09:14 PM
pistons4550's Avatar
I have the same problem. Being my first high performance sports car, I assumed it was normal.
Old Jan 2, 2015 | 02:07 AM
wowzers's Avatar
Plugs are fairly new probably less than 1,500 miles for the Iridiums.
Yeah ill be getting a coil kit.
Yeah seems like a few people on here have confirmed that this is the case and is normal.
Old Jan 2, 2015 | 07:40 AM
I will also be going SD and getting the spoolinup COP kit. That should definitely take care of it.
Old Jan 2, 2015 | 09:19 AM
06mr775's Avatar
Cams and clutch are usually the reason. Switching to SD helps a little but it will still more or less act that way even after
Old Apr 21, 2015 | 05:23 PM
4Bangah's Avatar
Same for me.. hope this gives some reassurance
Old Apr 21, 2015 | 07:02 PM
Jonno99's Avatar
clutches engage disengage or slip
Is the jerky related to one of these?
Old Apr 21, 2015 | 10:21 PM
alleggerita's Avatar
SD, Sparktech COP and 2-piece driveshaft each improved things a bit. SD was most noticeable. A tiny bit remains ....
raytrix
13
Jun 8, 2010 08:11 AM
jackfrog
Feb 1, 2010 12:16 PM
dtuned
Jun 4, 2009 02:02 PM
RevvDon
Driving Techniques
11
Jan 25, 2004 10:22 AM
zlaxman
Lancer Troubleshooting
20
Jul 11, 2003 07:39 AM
