Clutch will not disengague
Old Feb 4, 2015 | 03:54 PM
J Woody's Avatar
I deployed and my evo had to sit through 6 long months. I planned on doing complete overhaul when I got back: engine build, suspension, mini bat kit, new turbo kit, paint job....everytjing. So it kinda just Sat there for 6 months. When I got back the battery was dead as expected. But once I got it running the clutch dose not disengage anymore. What could have happened over 6 months outside to cause the clutch to just quit doing what he is paid to do?
Old Feb 4, 2015 | 06:42 PM
Jonno99's Avatar
maybe air in the clutch fluid, bleed required
https://www.evomoto.com/tech_article..._article_id=17
Old Feb 4, 2015 | 07:40 PM
J Woody's Avatar
I have already bled it. I cycled all the fluid
Old Feb 4, 2015 | 08:12 PM
Jonno99's Avatar
is the piston being pushed into the lever on the bell housing? I can't see how the clutch would totally fail from lack of use
Old Feb 5, 2015 | 08:06 AM
J Woody's Avatar
Yes the piston moves the lever on the housing. Not sure if it's all the way. But if defiantly moves
Old Feb 5, 2015 | 08:10 AM
J Woody's Avatar
I took the rubber thing off the top of the trans and you can see the trans spinning when the car is running. When you press the clutch the lever on bell housing moves but clutch keeps spinning. Everything feels normal with the clutch pedal, clutch has 700mi on it. Professionally installed by evo dynamics.ran fine for 700mi then I parked it.
Old Feb 5, 2015 | 11:34 AM
06mr775's Avatar
What kind of clutch is it?
Old Feb 5, 2015 | 12:45 PM
J Woody's Avatar
Competition stage 4
Old Feb 5, 2015 | 08:33 PM
J Woody's Avatar
Fixed it before step 7!
Old Feb 5, 2015 | 08:39 PM
J Woody's Avatar
http://www.chicagolandmgclub.com/tec...neral/604.html
Old Feb 6, 2015 | 11:29 AM
06mr775's Avatar
lol I was just about to suggest trying exactly that. Ive seen this exact kind of problem on a supra before.
Old Feb 22, 2015 | 09:09 AM
fanbelted's Avatar
I think those instructions are for a rear-wheel drive car, since it says to leave the 2 front wheels on the ground. For AWD, you will need to get all 4 wheels off the ground with jack stands. And obviously, will not be able to try the last technique with releasing the seal on the floor jack.
evovin
22
May 29, 2008 03:46 AM
Last4G63
21
Mar 9, 2008 09:48 AM
drewblueeye
Jun 15, 2007 08:50 PM
vegasboy301
Jul 11, 2006 01:57 AM
