boost leak test compresor leaking
Old Feb 26, 2015 | 09:09 AM
phrequenc's Avatar
I'm trying to do a boost leak test, but my turbo is leaking from the cold side behind the cover. i can't build barely any psi on it at all.
i read through a thread and saw this
- Run your finger along the backside of the turbo compressor cover. If you feel a jet of air, from either the cover seam or at the head of a cover bolt, be prepared to remove the compressor cover and reaffix with a bead of gasket sealer (e.g. Permatex gray). This is a common problem with newer Garrett turbo covers.
its a few years old thread, but does this still apply? its a brand new turbo and only been started up and moved around never even driven. I'm prepping the car for a tune and this is the last step i have to do beside fix my oil pan leak
any help greatly appreciated
the turbo is a fp hta 86
Old Feb 26, 2015 | 11:37 AM
evotuner04's Avatar
15 Year MemberLikedLoved
Id imagine if thats the ONLY area leaking then yes you should probably pull it out and look into problem.
Old Feb 26, 2015 | 11:39 AM
AreSTG's Avatar
Yeah its normal. If you get a garret based turbo from FP you should do a small bead of RTV. Someday they may come with an o-ring built in. Until then, clicking the turbo is a pain in the butt...
commbubba19
May 9, 2016 08:15 PM
okevolutionVIII
Nov 19, 2013 11:22 PM
evo9ben
21
Oct 12, 2012 06:44 PM
Wirk
Oct 4, 2012 04:31 PM
evilrevo8
10
May 17, 2009 03:09 AM
