How do I get 400whp?
Old Feb 28, 2015 | 04:44 PM
Murder-evo's Avatar
Hey I'm completely new to this kind of thing but I have a stock 05 Evo 8 I want to reach around the 400awhp range but my limit on cash is 3k what are things that I can do to get it up to what I want and still have a reliable motor and tune
Old Feb 28, 2015 | 05:02 PM
Bhsj13's Avatar
if i had 3k for a completely stock evo this is what i would do:
-TBE
-K&N panel filter
-Walbro 255
-Lower IC pipe
-1000+cc injectors
-turbo O2 housing upgrade
-some 272 cams if you have the money(well worth it)
-headstuds
-BOV if you have the plastic one(crush the 9 BOV or Synapse or COBB)
-E85 tune
*might be a little over 3k after everything if you dont do installs work yourself*
you will be in the higher 300's on a dynojet. 400 will not be achieved on that turbo. a FP green will do it on E85 no problem. If you want 400 on pump, you will probably get it on a FP red but it will require a IC upgrade to help temps stay lower imo.
Old Feb 28, 2015 | 05:22 PM
e_kobz's Avatar
Is E85 available to you?
Old Feb 28, 2015 | 05:59 PM
REV.olution's Avatar
A shocker sticker and search button. Sticker first.
Old Feb 28, 2015 | 06:10 PM
Murder-evo's Avatar
E85 is not available for me
Old Feb 28, 2015 | 06:55 PM
shavkatjon2000's Avatar
if i had 3k i would get these
GSC s2 Cams/ Kelford 530$ ( i would not get it used but if your tight on money you can get one )
springs and retainers 360$+ ( i would not get it used)
Walbro 255 50$+ (i would not get it used)
1000+CC Injectors 350$+ ( i would not get it used)
Upper Lower FMIC piping 350+ ( Can Get it used don't have to be new)
FMIC ETS 3.5 or AMS 450$+ (you can get it used don't have to be new)
Turbo Back Exhaust (if you don't have it ) 1000$+ - depends on Brand
Tune 450$ + - depends on tunner
Plus Installation and stuff looking about 1000$+ -
with these you should be close to your goal with a tune if you had little extra cash i would throw a FP RED
Old Mar 1, 2015 | 05:24 AM
evo8426's Avatar
Everyone suggesting to go to a Red or Green, you need to add in the price of a new downpipe ($600+) and a wastegate ($265+) since these are no longer direct plug and play.
Old Mar 1, 2015 | 06:51 AM
NSDQ's Avatar
He did say he wants to be "around" 400awhp, not that he has to have 400...I'd suggest stick with the bolt-ons others have mentioned and enjoy your car. Once you go route of changing turbos the can of worms is going to open, even on a mild turbo like a green or red.
Old Mar 1, 2015 | 07:07 AM
egis's Avatar
Old Mar 1, 2015 | 07:39 AM
drive955i's Avatar
By can of worms, I assume you're referring to the endless stream of cash flowing from you wallet into the turbo intake. I definitely agree with the thought. Some people know when to say when, but people, like us, that love cars (why else would you own an Evo) will almost undoubtedly not be able to do so. Stay with the stock turbo, at least for now, and focus on better engine breathing through a turbo back exhaust, intake, intercooler piping, intercooler, then some injectors, a manual boost controller, a Walboro or equivalent fuel pump, some higher lift/duration cams, O2 housing, an Evo 9 recirc valve or blow off valve of your choice, and a tune. You probably won't get to 400, but you'll get relatively close, and you will be impressed with how much power that little two liter can push. Besides, once you reach this power level, you may find other areas lacking that require more attention.
seahawks12th
41
Jun 15, 2009 01:05 PM
EvolNinja
16
Feb 21, 2009 03:58 PM
MR.IVMR2YOU
May 29, 2008 12:58 PM
slowevo4u
46
Jul 4, 2007 02:08 PM
