Catch Can question.
Old Mar 30, 2015 | 12:51 PM
jtcarstens's Avatar
Catch Can question.
Ok so my question is this; Most people install one hose of a catch can with a breather to the valve cover and the other side to the intake pipe.
What would happen if I did one side from the PCV in the back of the valve cover to the can, then capped the other side off. Then the other side of the valve cover to the other side of the can, and capped the intake tube off.
so basically all blow by is going straight into the catch can and nowhere else. Is this a thing, am I retarded?
Old Mar 30, 2015 | 03:09 PM
STLEVOIX's Avatar
That's how mine is setup. I have a baffled can and a breather filter on top. Matt of fact this is the one I run with out any issues..
http://streettunedmotorsports.com/pa..._catch_can.htm
Old Mar 30, 2015 | 06:38 PM
xMCxMRx's Avatar
Mine is ran that way,I'll get a picture of mine for you tomorrow.
Old Apr 1, 2015 | 09:52 AM
GTijoejoe's Avatar
You are describing a recirculated catch can vs non recirculated.
Recirculated goes back to the intake pipe as it vacuums the vapor from the crankcase/head.
Non Recirculated uses a vent to catch the vapor being pushed out by crankcase pressure.
Old Apr 1, 2015 | 11:34 AM
chu's Avatar
chu
I assume by the awesome drawing that its a non-recirculated setup. In which case is fine.
I do prefer a close system personally, because I like the idea of the intake helping to draw pressure out of the crankcase. I ran Saiko Michi catchcans on my old Evo, and the closed system works really well. Just a note, on the PCV valve, its completely closed under boost, rendering the vent useless to relief crankcase pressure.
Old Apr 2, 2015 | 09:37 AM
xMCxMRx's Avatar
Here's a picture of how mine is ran.
Old Apr 2, 2015 | 06:37 PM
Insanity Evo's Avatar
Where did you get that setup? It looks really nice
Old Apr 3, 2015 | 03:45 PM
xMCxMRx's Avatar
I appreciate it dude! My buddy is a fabricator and this is what he made for me. He runs a very similar one on his supra.
Old Apr 3, 2015 | 06:33 PM
nursebetty's Avatar
im running this set up, not sure if it would work with different sides of steering.
http://atperformance.com.au/product/...oil-catch-can/
Im in Aust with jdm evo 7
Old Apr 4, 2015 | 12:36 PM
lostsoulsevo's Avatar
With a VTA setup, make sure you monitor all the time. Your can will fill up quick if you're always WOT
Old Jul 5, 2015 | 05:45 PM
Deathbox's Avatar
I have a JM fab catch can, it has a si gle breather and the recirculated setup. I'm pushing about 500hp on 30psi on a ported FP black turbo and an AMS 2.3RR sroker crate engine. Ive been looking into the STM catch cans because they have a greater capacity and some with dual breathers. The one I have now will spray everywhere if I run to hard, or cruise at 80mph+. Oil and yellow gunk on the windshield/ engine bay for days... Anyone else ran into this issue?
BaumBizzle
17
Sep 24, 2012 11:59 AM
anthonyrb98
50
Sep 11, 2011 07:49 AM
riceball777
14
Dec 23, 2006 09:39 PM
