2002 - Only Battery light on - Battery & Alternator checks good
Old Apr 1, 2015 | 08:24 AM
waid302's Avatar
In my 2002, only the battery light on. The brake light is not on. I had the alternator & battery checked at 3 different places and both checks good.
Any idea what would be causing just the battery light to be on ?
Thanks
waid
Old Apr 1, 2015 | 12:54 PM
LetsGetThisDone's Avatar
What is the system voltage with the car running?
Old Apr 1, 2015 | 01:32 PM
chu's Avatar
chu
Check the alternator connections to make sure it isn't loose and tripping the light. You could reach it from underneath the car.
Old Apr 1, 2015 | 04:46 PM
waid302's Avatar
At the battery with car off, my multi-meter reads 12.2V. With car on it reads, 15.5V. However, with my Android OBDII Scanner, it reads 14.4V.
Waid
Old Apr 7, 2015 | 08:13 AM
waid302's Avatar
Found the problem! The Orange battery sense wire (Pin 2 on B-25) at the Alternator was broken but still attached to the alternator. I started from the Battery and traced it back to find where it was disconnected. Once I connected it, the light went away and all is well.
What is interesting is I went to 4 different auto parts stores with the Alternator and Battery and got 4 different answers as to what is bad. One AutoZone said the Alternator was bad and other one said it was good and both said the Battery was fine. O'Riley said Battery and Alternator was fine. CarQuest said Battery was bad and Alternator was good. So go figure!
Thanks
tswift
Lancer Vendor Classifieds
94
Apr 2, 2004 03:11 AM
KN-James
10
Jan 5, 2004 01:31 PM
BigBoogieman
Northeast Region
23
Dec 9, 2003 05:00 AM
