Doing valvesprings... dropped a valve...
Old Apr 9, 2015 | 05:50 PM
black_beauty's Avatar
Im pretty sure I know the answer to this question but is there any way to fish a valve out w/o pulling the head? And if not can I just pull the exhaust manifold and leave the intake manifold on the head? I know Im an idiot. I didn't let my compressor fill back up apparently and when I popped the retainer off it was game over... Any help is appreciated...
Old Apr 9, 2015 | 06:38 PM
LetsGetThisDone's Avatar
you MIGHT be able to use a magnet and fish it up through the port, then use some long thin needle nose to coax it back into the guide/seal. Good luck...
Old Apr 9, 2015 | 06:43 PM
the pen magnet I have wont go through the guide, I guess I can go to a parts house and see if they have a thinner one...
Old Apr 9, 2015 | 06:45 PM
no, take whatever manifold off you need to, and use a bendy magnet to fish it up through the port.
Old Apr 10, 2015 | 05:35 AM
DSMolition's Avatar
Just put that cyl in tdc and do the valves accordingly. They can only drop a little bit.
I would try to take off the intake or exhaust manifold and try to work with it from there before you pull the head if you can. good luck!
Old Apr 10, 2015 | 07:55 AM
well I guess ill be pulling the exhaust manifold since its the easiest one...
Old Apr 10, 2015 | 10:02 AM
DSMolition's Avatar
Well was it the exhaust valve that fell? you need to pull the right one!
Old Apr 14, 2015 | 07:10 AM
1UpMoto's Avatar
If it fell completely out of the guide I highly doubt you will be able to get it back in. If it is still in the bottom of the guide it shouldnt be too hard..
Old Apr 16, 2015 | 04:51 PM
unfortunately not 1UP, I can pull the stem out the exhaust port... Ive tried fishing line and thin wire but it doesn't wanna come back through the guide
Old Apr 16, 2015 | 05:16 PM
you cant get long and thin needle nose pliers in the port to help get it into the guide?
Old Apr 19, 2015 | 01:15 PM
I can but its a snug fit and cant get enough upward pressure to get it back into the guide.
Old Apr 19, 2015 | 01:50 PM
heavens turbo's Avatar
I would just bite the bullet and buy a headgasket and yank the head. it sucks, but that's the easiest way to do it. unless you can get the valve at an angle and started into the guide, and get a small wedge to push from the bottom, enough to get some stem sticking out so you can grab it. you will need about 3-4 hands though.
Old Apr 19, 2015 | 02:03 PM
im pulling the head
90zcrex
31
Nov 1, 2014 11:09 PM
BogusSVO
Dec 5, 2012 09:50 AM
AWD_Terror
11
Jul 14, 2009 09:30 PM
JustDSM
13
Sep 13, 2005 10:04 PM
forum04pl
47
Aug 2, 2005 06:04 AM
