hids not working
Old Apr 9, 2015 | 09:39 PM
Bladey's Avatar
hids not working
Hey all so recently my factory hids stopped working I'd have to click them on and off 6 or 7 times to get them to light up once they where on all was good. They now no longer turn on no matter how many times I turn them on and off. When I turn them on the left side blinks 3-4 times then the right one blinks 3-4 times then they just turn off . I have replaced both the ballasts and the bulbs on either side and still have no such luck. Any input would be extremely handy as I would love to drive the car again.
Kind regards
Old Apr 11, 2015 | 06:19 PM
heavens turbo's Avatar
theres a couple of fuses and a relay for the headlights. it's possible a voltage spike could have popped a fuse, and the relay may have been on it's way out. swap the relay with a known good one, and check your fuses. I had an aftermarket kit that started to burn out, and just took it out and went back to regular bulbs. good luck.
Old Apr 11, 2015 | 09:24 PM
Bladey's Avatar
So today I took apart the dash and tested the headlight switch stalk and that's all working fine. I also borrowed another headlight from a friend's evo and same problem. Checked all fuses and replaced them . Could it be the front ecu/ atcas thing I've been reading about causing issues
Old Apr 18, 2015 | 02:56 AM
Bladey's Avatar
bump
Old Apr 19, 2015 | 03:58 PM
spitefire1's Avatar
hids not working
sounds light to me a bad ground or a hid ballast going bad. mine old hids did the same thing
Marroccowned
21
Jan 18, 2011 06:33 AM
Rguy
Nov 2, 2009 10:53 AM
slicedbreadno2
Midwest Region
Aug 6, 2008 11:29 AM
FunkyR
Dec 20, 2006 09:24 PM
wtz
Feb 12, 2005 04:53 PM
