Evo Misfire Please help, tried almost everything
Old May 14, 2015 | 01:40 PM
buckmarley's Avatar
I just have boost gauge atm and no do not have tatrix 2.0.
Old May 14, 2015 | 01:42 PM
m.al-hassawi's Avatar
Which can help
Old May 14, 2015 | 01:44 PM
buckmarley's Avatar
I can lower boost with tatrix?
how does it work exactly?
Old May 14, 2015 | 02:37 PM
You have to have tatrix 2.0 openport and then download ECUflash and you can change it from ecuflash but you dont have to change the boost settings if you didnt do anything on ur car i think its a failure maybe a damged vacuum hose or not connected properly put a zip tight on them
Old May 14, 2015 | 02:48 PM
BlackHawk_Tsi's Avatar
need for a tactrix.
With a tactrix you can do ecu modifications, tuning, logging and other great things.
But I think you need to keep it simple and find out why you are getting misfires. Maybe have a fuel pressure and air/fuel ration gauge as well will help you out.
Fix what's broken and then make improvements.
I'd guess to say its a bad fuel filter, ignition coil, or boost controller related.
Old May 14, 2015 | 07:08 PM
IzzyRS's Avatar
Fuel filter should be cheap to replace. Pull the fuel pump and look at that sock. Triple check all vacuum lines. Make sure your fuel pressure regulator vacuum line is good.
Disconnect the battery for a few minutes just to reset fuel trims. Get a wideband ASAP.
Old May 20, 2015 | 01:07 PM
buckmarley's Avatar
Hey guys sorry took so long for reply. So my vac hose connecting to cold side of turbo was singed through from the fan shroud.
i replaced the hose and all was working fine no more boost cut. However i am now only maxxing 10 psi on wot.. any clue to whats going on??
Old May 20, 2015 | 04:20 PM
Check where the vacuum hoses connected for rubber debris. If nothing. Treat it as a new problem. Boost controller? Boost leaking? Several reasons as to why you're under boosting. Stray new thread and post alot file. I know that helps the advanced members on here.
Old May 23, 2015 | 01:17 PM
buckmarley's Avatar
Okay thanks i heard i need to use oem boost hoses could that be the case
Old May 28, 2015 | 08:01 PM
Not really, I'm not an expert in turbo dynamics, but I'd figure that if the hoses are wider than OEM the reading would have a delay, but it would be milliseconds and unnoticeable.
Keep us posted?
red_evo_hoe
Oct 4, 2024 04:28 PM
2006GSR
Aug 20, 2016 09:22 PM
Green_Bandit
Lancer Engine Management / Tuning Forums
11
Jan 16, 2012 11:54 PM
momo_EVO8
May 8, 2009 01:00 PM
