Need PN for Evo 7 front badge and bracket
Old Jun 10, 2015 | 03:27 AM
QwikEVO's Avatar
I've been searching for the part number for the badge for an Evo 7 front badge and the bracket that holds it to the grille...and coming up empty.
the PN I have found crosses to the 9....are the front badges the same?
Just need the PN's so I can have a badge on my 7 bumper.
Thanks!
Old Jun 20, 2015 | 06:41 PM
LCS's Avatar
LCS
There is no bracket on the VII front upper grille. What seems to be a bracket is a vertical strip that connects one middle to one upper plate, making a reinforcement frame for the upper part of the bumper. The grille is bolted around it.
The front badge has two lower hooks - to lock in the net - and a upper threaded part for the bolt that runa from behind that vertical strip of the reinforcement.
I can get you the part numbers in two days. Had to buy those parts for my car.
Old Jun 22, 2015 | 07:22 PM
QwikEVO's Avatar
Thanks I'll keep an eye for your findings.
Old Jun 23, 2015 | 03:18 PM
LCS's Avatar
LCS
Hope this helps. Theses are from the 2001 Evolution VII:
Front Emblem Diamond Red - MR957901
Front Upper Grille + bumper reinforcement - MR574318
Old Jun 23, 2015 | 03:19 PM
LCS's Avatar
LCS
If you can't find them in the USA you should check out this site:
www.amayama.com
Old Jun 23, 2015 | 06:07 PM
QwikEVO's Avatar
You kick ***, sir. Thanks!
Old Sep 6, 2015 | 02:18 PM
danfalcas's Avatar
Indeed... Thanks!!!
If you could help me with the lower grille and side grilles PN would be awesome too.
Shogo1
May 1, 2011 10:54 PM
foam
Dec 15, 2010 09:12 PM
abdizzle
13
Jul 12, 2009 07:04 PM
trevor
73
Aug 11, 2006 12:45 AM
