HVAC controls links-Hard to turn problem..
Old Jul 25, 2015 | 08:09 AM
greenman's Avatar
Hi friends.
My car is 2007 Mitsubishi Lancer and it is have a auto clima.
My problem is hvac controls links hard turn problem.
2 control module is fine works but links hard turn.So I'm turning my hand that makes hot or cold.
a few solutions mentioned in the Forum but I think they clima manual.
Please help me.
I'm sorry for my bad english..
Old Jul 25, 2015 | 11:22 AM
barneyb's Avatar
Does this car have a cabin filter? The first USDM Evos did not have a cabin filter and other than the idiot design of the original levers, the problem was outside debris getting into the heater box and jamming the blend door. It could be the fix is pulling the heater box and replacing the door.
Old Jul 25, 2015 | 01:40 PM
greenman's Avatar
Thanks Friend for answer.
"t could be the fix is pulling the heater box and replacing the door."
Can you explain this sentence a bit more.. Because I cant understand...
Old Jul 26, 2015 | 11:16 AM
barneyb's Avatar
First of all you didn't answer my question. I asked if the car has a cabin filter. No filter allows leaves and whatnot get into the blend door mechanism and this door is what mixes hot and cold air for the desired temperature. If no cabin filter then this could be your problem.
Anyway there is a Technical Service Bulletin for a manual hard to move blend door on USDM Evos and part of the service is replacing the blend door. Well, replacing the blend door is not simple. The dash has to come out and the A/C has to be evacuated and disconnected in order to pull the heater box.
alexisrc
Jan 16, 2022 08:02 PM
greenman
Aug 15, 2015 08:44 PM
dookiedang
Sep 22, 2012 06:59 PM
From 3 to E
Jun 20, 2012 09:31 PM
XstormtrooperX
May 5, 2011 06:08 AM
