How to calibrate the omni 4 bar in evoscan
Hey all,
I am trying to get the 4 bar to read proper here at altitude in evoscan so I can make sure the boost logs fine. My question is what parameter do I need to adjust and to around what numbers so I can make sure that while the car is off it reads 0? Also is this the proper parameter to be logging and adjusting?
Thanks all!
Chad
Thanks all!
Chad
The Eval is what needs to be changed. You'd need to figure out how altitude affects that, what alt you are at and then adjust from there. to get it to read 0 when off...you log it when off and then subtract the value above 0 it is showing from eval and then you'd be set. Search around in the EcuFlash forum since this is covered there.
sponge bob
Jan 18, 2006 08:29 PM
