Engine bay connectors
Old Oct 29, 2015 | 05:40 PM
mileb's Avatar
anyone know where to get random connectors for the engine bay? something im interested in doing is getting the 3 acd connectors and making a clean extension harness in order to relocate the pump and minimize cutting. any info would help. thanks
Old Oct 29, 2015 | 06:02 PM
LetsGetThisDone's Avatar
Pull the pins out of the connector, carefully undo them and free up the wires. Extend the wires, put the pins on the end of the now extended wires, carefully recrimp, and solder for security.
Old Oct 30, 2015 | 10:46 AM
JAM.evo.7/9's Avatar
spooling up has most evo connections. with or with out pigtails
Old Oct 30, 2015 | 02:22 PM
wheatbix's Avatar
Spoolinup does have lots of connectors, but not the ones for the ACD as far as I'm aware. I'd still go with the middle suggestion of pulling out the pins and extending.
Old Oct 31, 2015 | 03:32 AM
Mr Gears's Avatar
Do you mean the Proportioning Valve, Pressure Sensor and Electric Motor connectors?
These are not so random. They are in fact very common. The one for the valve is the same as your cam sensor (Spoolinup has these). The pressure sensor is AMP 070 Econoseal. The motor connector is the same as DSM or Mitsubishi ABS pump motor. I think the best way to extend wires is have both the male and female connectors and plug it in as an extension adaptor. That way there is no modification or damage to the original harness. If you cant get a hold of new connectors and terminals, snip some pigtails from the junkyard and solder the wires together without tampering with the terminals.
You might be able to find a local supplier. Here are some example pics of what I think you are looking for.
Available here
https://sites.google.com/site/mister.../3p-connectors
Old Oct 31, 2015 | 07:28 PM
mileb's Avatar
thanks for this you read my mind as to what I was planning. im going to double check my connectors and let you know how it all turns out.
Old Oct 31, 2015 | 07:40 PM
kaj's Avatar
kaj
Where are people mounting their pumps and reservoirs? Aren't there locations from the non-usdm versions?
Old Oct 31, 2015 | 08:37 PM
mileb's Avatar
Either in the trunk or under the car behind the rear wheel is where they get relocated. Non-usdm version have it mounted in the trunk but I forget which side since the left has the tools for the spare tire and the right side has the spray bottle.
Old Oct 31, 2015 | 08:42 PM
mileb's Avatar
Available here
So the connector you posted and linked are both correct when I compare them to the photo I took today. The third connector the power connector is a 2 pin and I cant find them online for sale but I will check an ABS pump motor from my buddies dsm to confirm. Thanks again for this info.
Mr Gears's Avatar
Non US cars have the ACD/AYC pump mounted just behind left rear wheel, underneath the car (drivers side for the US). The reservoir is located in the Trunk (sort of the same spot as wiper fluid, but other side of car). I believe the person to blame for this is big Arnie and his Californian mates. Harsh emission standards require USDM car to have extra pollution gear near the fuel tank. This required the ACD pump to need to be relocated to provide room for extra pollution gear. This is the story I have heard, I have no way to verify the accuracy.
Fortune-Auto
Evo 'For Sale' Exterior Styling
217
Feb 20, 2013 06:16 PM
personal_golf
Feb 14, 2011 07:40 AM
Fortune-Auto
EvoX 'For Sale' Exterior Styling
59
Apr 30, 2010 06:40 AM
xxitr
12
Sep 16, 2009 04:25 PM
