Engine lag
Old Dec 24, 2015 | 01:52 PM
Adam Keith Lang's Avatar
Engine lag
I have a 03 evo 8 and out of nowhere my car will make boost to 20lbs like it was before (normal) and engine won't get up and go just barely accelerates at all very slow to none pick up need help replaced the fuel pump and still have the same issue.
Old Dec 24, 2015 | 04:05 PM
kaj's Avatar
kaj
um. wut?
Old Dec 24, 2015 | 04:14 PM
RallySport9's Avatar
sludge, could be the years of sludge and it stuck the engine is stuck.
Old Dec 24, 2015 | 06:23 PM
moyassine's Avatar
we need a little better information so people can help you, your post made close to no osense
Old Dec 25, 2015 | 02:05 AM
masterkabal's Avatar
Changed the spark plugs already?
Try NGK BR8ES and gap it to 0.55 mm.
Old Dec 25, 2015 | 01:05 PM
FTONOOB's Avatar
It indicated 20 psi on the boost gauge and the car still not performing? Is it stock? trying to piece together your info.
Old Dec 25, 2015 | 04:32 PM
Car has bolt on mods intake manifold throttle body exhaust intercoolet piping headers that's bout it but I haven't had a issue had all the parts on for months but yes the gauge reads fine goes to 20psi let off bov works but engine doesn't increase rpm like it should it's like a snail
Old Dec 25, 2015 | 04:42 PM
e_kobz's Avatar
Brake boosting
Old Dec 25, 2015 | 04:45 PM
I looked at the spark plugs they are fine
Old Dec 25, 2015 | 06:46 PM
FTONOOB's Avatar
So the car boosts but it's not accelerating? How the fueling looking? How's it idling? Compression is good?
Old Dec 26, 2015 | 07:30 AM
Yes and just replaced the fuel pump idle is below 1,000 and rough
Old Dec 26, 2015 | 07:55 AM
Jhero23's Avatar
Any particular reason why you replaced the fuel pump? What was the old fuel pump? what is the new one?
Old Dec 26, 2015 | 09:43 AM
Had a guy who is a mechanic told me to when I told him what was goin on and I got a walboro 255
Old Dec 26, 2015 | 10:25 AM
FTONOOB's Avatar
You need to find out what's going on at the point of the problem. I would advise against swapping parts that you think are causing the problem. Get as much data as you could to diagnose the problem instead of reacting to symptoms. You need to get diagnostics done to see what the fueling is while driving. MAF, MAP, injectors, knock sensor etc could be culprit. You have some digging to do.
Old Dec 26, 2015 | 12:43 PM
Ok thanks
