How to Clutch / Pedle adjustment ! Help
Old Dec 28, 2015 | 02:01 PM
CahitGP034's Avatar
guys can someone help me to adjust my clutch im not exactly sure how to all i know that is theres a bolt at the back of the pedle and etc.. ( my clutch pedle is way up i dont have to fully press down to change gears .. ( this is a new clutch i just installed so help would be nice from you guys thanks !
Old Dec 29, 2015 | 05:21 AM
egis's Avatar
All you know there's a bolt in the back of the pedal. Have you physically laid on your back in the foot well with the flash light in hand and wrench in another?
http://www.evomoto.com/tech_info.php?tech_id=28
Old Dec 29, 2015 | 05:34 AM
CahitGP034's Avatar
alright thanks i managed to do it gears go in fine and feels better then the last time even tho it feels a little stiffer its a new clutch so i guess i should wait and find out if it gets better.. also to say i dont have to push all the way for the clutch to change gears even if its pusshed till the middle i can change gears is that alright ?
Old Dec 29, 2015 | 07:02 AM
egis's Avatar
If it's ok with you that clutch grabs from the middle I don't see a problem. Usually most of us prefer 1/2-3/4" free play.
Old Dec 29, 2015 | 07:06 AM
CahitGP034's Avatar
ahh ok then thanks allot man! just worried .. dont want to buy another clutch becouse of a small error.
Old Dec 29, 2015 | 07:35 AM
CaptainSquirts's Avatar
Per TRE....
Recently it came to my attention that there are quite a number of drivers who believe their clutch foot should start engaging the clutch before they've completed the shift into a gear. WRONG.
I haven't a clue as to where people came up with that idea but it is not the correct way to shift a manual transmission and you better damn well understand that your clutch has to be fully disengaged when you cross over the neutral gate and that you don’t start engaging the clutch until the transmission is fully into gear.
Think about gun slinging for a moment… You don’t pull the trigger until you have your gun out of the holster and the barrel aimed at the target or you’re going to miss and end up shooting at the dirt.
So to be safe I would just press the clutch pedal all the way down..
Old Dec 29, 2015 | 01:40 PM
06RedRalli's Avatar
I was always taught the proper way to adjust the clutch pedal in an evo is as follows.
In a running car, push the clutch pedal all the way in, and push the gas pedal to bring the rpm's up to 6500-7000. If the car moves at all then the clutch pedal needs to be adjusted higher meaning the clutch would engage further away from the floor board.
And if the car doesn't roll forward or move, then you can engage it so it engages closer to the floor board, but once the car moves at its closest point to the floor board possible, then you can back it up just a tad and be all set.
Old Dec 29, 2015 | 07:46 PM
Cal City Evo's Avatar
Really what kind of RETARD would free rev their car to 7K?
That would be CLASSIC if it just shot forward!!!!!
Old Dec 29, 2015 | 08:06 PM
06RedRalli's Avatar
http://www.jackstransmissions.com/pages/clutch-drag-kills-synchros
Old Dec 30, 2015 | 11:45 AM
boxerdropper's Avatar
Not uncommon. adjusted a few this way. I do feel kind of bad revving it so high but it needs to be done
4G63 4EVR
Jun 6, 2013 04:25 PM
Johnboy1065
Mar 23, 2008 03:48 PM
Jib
South Region
Aug 11, 2006 07:22 PM
Zemo
18
Jun 28, 2006 05:38 PM
plokivos
Jan 22, 2005 02:05 PM
