I just don't get it!
Old Dec 30, 2015 | 04:48 PM
6466Animal's Avatar
So I just did my head gasket and everything was great! And still is! BUT now that the temperature dropped of course I get my e85 smoke BUT (again) now I get a good amount of smoke and idk if it's my tune cause it's having a hard time staying on so idk of its dumping fuel or it's a coolant problem cause my heat isn't as strong and I wonder if it's my turbo!
Old Dec 30, 2015 | 05:23 PM
Turndown's Avatar
Veteran: Army
If you have a wideband watch that as it idles and it should give you a good idea if it's dumping fuel or going lean. If you don't have a wideband, get one lol.
Old Dec 30, 2015 | 05:25 PM
6466Animal's Avatar
I do I'll def check it out any other suggestions!
Old Dec 30, 2015 | 05:45 PM
Turndown's Avatar
Veteran: Army
I'd check your coolant level as well to see if that's gone down at all.
Old Dec 30, 2015 | 05:53 PM
Pal215's Avatar
Happy Holidays,
If your heater isn't blowing as hot as it was before then there might be a little air left in your coolant system. This isn't the reason your car is stumbling and trying to turn off.
When it gets colder it takes my engine longer on E85 to warm up. That's just part of the cooling nature of E85 and the richness of it's tuning.
When you changed the head gasket, did you use the right torque pattern and did you increment the torque on each head stud little by little using oil? Torque all in sequence to 40lb then 60lb and finally 80lb.
I doubt that it's the turbo. Are you losing coolant or oil at a higher rate than normal?
Finally, does the car drive fine after it's fully warm and under boost ?
Timing set perfect? IX Mivec gear can make things difficult sometimes.
-pal215
Old Dec 30, 2015 | 08:02 PM
6466Animal's Avatar
Originally Posted by Pal215
Happy Holidays,
-pal215
Not losing oil or coolant and I know for sure I did the sequence right. Now thinking about it, I forgotten how long it really takes to warm up the motor and me having a huge mishimoto radiator isn't helping either lol! Haven't had the set up in the winter before! But when I'm at a light and I take off its a lik thicker than usual so I'm guessing it's dumping fuel trying to keep it running?
Old Dec 30, 2015 | 08:35 PM
roni4g63's Avatar
id say its most likely fuel too. plus in the cold the condensation can trick you alot, as it looks thicker the colder the weather gets.
Old Dec 31, 2015 | 09:05 AM
6466Animal's Avatar
It's usually when I'm reversing or come to a stop and it smells like straight e85! I'm going to go back to pump gas for the rest of the winter!
Old Dec 31, 2015 | 09:11 AM
Ev0ikon's Avatar
Clean your PCV valve.
Old Dec 31, 2015 | 09:32 AM
6466Animal's Avatar
Copy!
Old Dec 31, 2015 | 09:42 AM
LetsGetThisDone's Avatar
What color smoke is it? How much smoke is there? What are your AFR's?
EdT
Apr 6, 2006 04:16 PM
