Ac compressor keeps seizing at wot or high rpm
Old Feb 18, 2016 | 08:44 AM
Paulevo9's Avatar
Ok guys I really need help . My ac compressor keeps seizing after a big wot test ! After about 8k . Or so . Or just a lot of pulls . It my third one and I can't figure it out . I don't have my ac on while I'm doing this . I bought a new gate serpentine belt with every ac compressor oem. So idk . Bad tensioner or pulleys perhaps ? But they seem fine
Old Feb 19, 2016 | 08:36 AM
Paulevo9's Avatar
Damn no body's,
Old Feb 19, 2016 | 10:37 AM
Jmills's Avatar
Not sure personally but here's a free bump to see if anyone else knows.
Old Feb 20, 2016 | 09:46 AM
Paulevo9's Avatar
Thanks brother lol
Old Feb 20, 2016 | 12:49 PM
barneyb's Avatar
If the A/C is not on then the compressor shouldn't be running. The only way for the compressor to run if the clutch is deenergized if for the bearing in the clutch to fail. With enough wobble in the pulley maybe the compressor would run. So, my guess (only a guess) is that you are buying compressors with bad bearings. I imagine if the bearing fails while the engine is pulling 8K and the compressor suddenly starts running, the compressor is not going to be happy.
Old Feb 20, 2016 | 03:52 PM
EVOIX315's Avatar
the a/c compressor will run if the heater is on defrost as well. i would unplug the compressor and give it a shot for heck of it and see what happens. also with the serp belt off , all the pulled and tensioner move and spin freely?
Old Feb 21, 2016 | 09:17 AM
Paulevo9's Avatar
Well the compressor is aeized now buying a new one tomorrow .
Paulevo9's Avatar
[i did get the last one used but the one before that was new QUOTE=barneyb;11578949]If the A/C is not on then the compressor shouldn't be running. The only way for the compressor to run if the clutch is deenergized if for the bearing in the clutch to fail. With enough wobble in the pulley maybe the compressor would run. So, my guess (only a guess) is that you are buying compressors with bad bearings. I imagine if the bearing fails while the engine is pulling 8K and the compressor suddenly starts running, the compressor is not going to be happy.[/QUOTE]
prowakeskater
Aug 17, 2024 11:14 AM
Paulevo9
Feb 27, 2016 09:53 PM
Igaly1021
Nov 7, 2015 05:18 PM
bakuro117
10
Feb 27, 2013 10:05 AM
KOEvo
38
Oct 18, 2006 05:17 PM
